Warning message
Radius wont Authenticate Default Users
Answered Question
May 1st, 2014
I am using free radius on ubuntu 12.04 LTS.
The AAA configs I have, I  used on all of my Layer 2 devices, and it works successfully, however I can not get users to authenticate on a Layer 3 device.... here is some info... I can ping to and from my server, also I have rules on the asa 5510 allowing devices to talk to the radius server... as well as an access-list permit on the router....what am I missing.
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF13, RELEASE SOFTWARE (fc1)
the configs---
aaa new-model
aaa group server radius RadiusGrp
 server X.X.X.X auth-port 1812 acct-port 1813
aaa authentication login default group RadiusGrp
aaa authorization exec default group RadiusGrp
aaa accounting exec default start-stop group RadiusGrp
aaa accounting system default start-stop group RadiusGrp
radius-server host X.X.X.X auth-port 1812 acct-port 1813 key secret
radius-server retransmit 3
Debugging AAA authentication ---
May  1 13:22:24: AAA/AUTHEN/START (3020837816): port='tty1' list='' action=LOGIN service=LOGIN
May  1 13:22:24: AAA/AUTHEN/START (3020837816): using "default" list
May  1 13:22:24: AAA/AUTHEN/START (3020837816): Method=RadiusGrp (radius)
May  1 13:22:24: AAA/AUTHEN (3020837816): status = GETUSER
May  1 13:22:26: AAA/AUTHEN/CONT (3020837816): continue_login (user='(undef)')
May  1 13:22:26: AAA/AUTHEN (3020837816): status = GETUSER
May  1 13:22:26: AAA/AUTHEN (3020837816): Method=RadiusGrp (radius)
May  1 13:22:26: AAA/AUTHEN (3020837816): status = GETPASS
May  1 13:22:30: AAA/AUTHEN/CONT (3020837816): continue_login (user='thull')
May  1 13:22:30: AAA/AUTHEN (3020837816): status = GETPASS
May  1 13:22:30: AAA/AUTHEN (3020837816): Method=RadiusGrp (radius)
May  1 13:22:51: AAA/AUTHEN (3020837816): status = ERROR
May  1 13:22:51: AAA/AUTHEN/START (2366780039): port='tty1' list='' action=LOGIN service=LOGIN
May  1 13:22:51: AAA/AUTHEN/START (2366780039): Restart
May  1 13:22:51: AAA/AUTHEN/START (2366780039): no methods left to try
May  1 13:22:51: AAA/AUTHEN (2366780039): status = ERROR
May  1 13:22:51: AAA/AUTHEN/START (2366780039): failed to authenticate
May  1 13:22:53: AAA/MEMORY: free_user_quiet (0x44BFCBB8) user='thull' ruser='NULL' port='tty1' rem_addr='X.X.X.X' authen_type=1 service=1 priv=1
May  1 13:22:53: AAA: parse name=tty1 idb type=-1 tty=-1
May  1 13:22:53: AAA: name=tty1 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=1 channel=0
May  1 13:22:53: AAA/MEMORY: create_user (0x44BFCBB8) user='NULL' ruser='NULL' ds0=0 port='tty1' rem_addr='X.X.X.X.' 100authen_type=ASCII service=LOGIN priv=1 initial_task_id='0', vrf= (id=0)
May  1 13:22:53: AAA/AUTHEN/START (1597653700): port='tty1' list='' action=LOGIN service=LOGIN
May  1 13:22:53: AAA/AUTHEN/START (1597653700): using "default" list
May  1 13:22:53: AAA/AUTHEN/START (1597653700): Method=RadiusGrp (radius)
May  1 13:22:53: AAA/AUTHEN (1597653700): status = GETUSER
Correct Answer by Poonam Garg about 3 years 3 months ago
It seems that your radius server is not listening on udp 1812 port. Try to use 1645 and 1646 port for radius authen/author and accounting respectively and also apply firewall rules to allow traffic on these udp ports.
"Please rate helpful posts"
Overall Rating: 5 (1 ratings)
Correct Answer
Poonam Garg Thu, 05/01/2014 - 09:17
  • Silver, 250 points or more
Related Content
