Warning message
CUEAC server not showing directory
May 2nd, 2014
hellow all
i have installed CUEAC 9.1 server client, op can login easily but most of the options in CUEAC client are grayed out ad directory is not showing database also connected as showing in CUEAC, we need directory in cueac client also kindly help me out to solve thi issue.
Jaime Valencia Fri, 05/02/2014 - 08:44
  • Cisco Employee,
  • Hall of Fame,
    2011
Have you configured the features you want??
Have you configured the directory sync??
Khurram Tariq Fri, 05/02/2014 - 09:15
transfer button is grayed i dont think so its configurable??
i have confugured queue and its showing in it
yeah i did dir sync but in logs its empty i read blogs i changed the dir rule to telephonenumber equal to * but no luck
Aman Soi Fri, 05/02/2014 - 23:32
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Can u please  cross-check under System Configuration ---Directory Source Management, Synchronisation Status as Enabled if using CCMSource or LDAP?
You should get the contacts in Contact Management.
regds,
aman
Khurram Tariq Sun, 05/04/2014 - 01:12
hi
i am using enterprise edition and in it its under resource managment>data synchronization and its enable and connected but still not showing directory
Aman Soi Sun, 05/04/2014 - 01:25
    2017 IP Telephony
Hi , try restarting LDAP plugin in CUEAC.
regds,
aman
Khurram Tariq Sun, 05/04/2014 - 11:07
i did restart plugins and whole server, one thing i tell you i did not create end user and device profile in CUCM for my  users, only using device option to register phones.
should i make end user device profile and extension mobility for it ?
Aman Soi Sun, 05/04/2014 - 19:06
    2017 IP Telephony
this means that you do not have any end users created in CUCM or integrated through AD.
If that is the case, try creating few test end users and check whether they are appearing in contact management in CUEAC.
regds,
aman
Khurram Tariq Mon, 05/12/2014 - 06:25
Still not showing i have configured End user also but directory stil not here..:(
