Multi-Context Vs Anyconnect
pratheesh.venu
I understand from version 9.2 onwards ASA supports IPSec and Dynamic routing protocol in Multi- context implementation.
Will I be able virtualize Remote Access Solution by creating Multiple Context and and Create AnyConnect RA VPN solution? I am trying to use same ASA for two different customer RA VPN solution.
Also please let me know if there is any model specific statistic available to see how many concurrent Anyconnect sessions are allowed per device model. I am trying to get some input to see the appropriate model to support 10, 000 RAVPN users.
in Release for the Cisco ASA Series, 9.5(x) we have information:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa95/release/notes/asarn95.html
First Published: August 12, 2015
Last Updated: January 28, 2016
Remote Access Features
Support for Remote Access VPN in multiple context mode
You can now use the following remote access features in multiple context mode:
  • AnyConnect 3.x and later (SSL VPN only; no IKEv2 support)
  • Centralized AnyConnect image configuration
  • AnyConnect image upgrade
  • Context Resource Management for AnyConnect connections
Note: The AnyConnect Apex license is required for multiple context mode; you cannot use the default or legacy license.
We introduced the following commands: limit-resource vpn anyconnect, limit-resource vpn burst anyconnect
We modified the following screen: Configuration > Context Management > Resource Class > Add Resource Class
Notice: AnyConnect Apex license is required for multiple context mode
Kind regards,
Michal
P.S.
http://www.cisco.com/c/en/us/support/docs/security/anyconnect-secure-mobility-client/200191-AnyConnect-Licensing-Frequently-Asked-Qu.html?referring_site=RE&pos=1&page=http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect40/feature/guide/anyconnect40features.html
Q. How do I receive a trial AnyConnect Apex license for my ASA?
A. Cisco offers 4-week Apex evaluation licenses that incorporate all Plus license functionality. To obtain an evaluation license, please visit: https://www.cisco.com/go/license. Select the following: Get Other Licenses -> Demo and Evaluation -> Security Products -> AnyConnect Plus/Apex (ASA) Demo License.  Please note that the license unlocks the ASA functions, but does not grant access to the AnyConnect Windows/Mac OS X/Linux software. Mobile versions of AnyConnect can be accesed via the Application store for the specific OS and can be trialed in conjunction with an evaluation license.
After that, you can Configure a Class for Resource Management
http://www.cisco.com/c/en/us/td/docs/security/asa/asa95/configuration/general/asa-95-general-config/ha-contexts.html#ID-2171-000009a8
in system context:
class gold
 limit-resource vPN anyConnect 5
 exit
context CONTEXT-A
 member gold
and check in CONTEXT-A:
6 Replies 6
Marvin Rhoads
As of 9.2(1) there is still not support for remote access VPN in multi-context mode. (ASA 9.0(1) introduced support for IPsec site-to-site VPN in multi-context mode.)
Please refer to the ASA release notes page for details on new features by release.
As far as RA VPN clients, the 5555-X is rated at 5,000 concurrent AnyConnect VPN peers. The 5585-X with (SSP-20 or higher) maxes out at 10,000 concurrent AnyConnect VPN peers (source).
Rather than buy one big box though, a more scalable solution would be to build a VPN cluster. That allows you to grow more linearly (up to 100,000 users with a large cluster) and gives better resiliency.
Kind regards,
Michal
P.S.
in system context:
class gold
 exit
context CONTEXT-A
 member gold
Hello
Nice article for doubts and clarifications
small doubt is after enabling Anyconnect APEX license only SSL is supported or IKEv2 will also support
Hi Muhammad,
Both SSL and IKEv2 would be supported.
Aditya
Please rate helpful posts.
Thanks for your support
so its clear only after enabling it will work
could you please tell me the part number for ordering purpose
Muhammad,
There are two part numbers required for an AnyConnect Apex order - the term license and associated term subscription.
Term License: L-AC-APX-xYR-G
Term Subscription: AC-APX-xYR-zzzz-S
(x = 5, 3, 1) year term
(zzzz = 25, 50, 100, 250, 500, 1K, 1500, 2500, 3500, 5K, 10K, 25K, 50K, 100K, 250K) unique users
