Warning message
VPN IPSec with CISCO 1900 (15.3) and MikroTik RouterOS (5.26)
May 3rd, 2014
Hello!
I configured an IPSec Tunnel between CISCO 1921 with IOS 15.3 (with securityk9 and ZBF) and MikroTik RouterOS (5.26) - both fiexd IP Adresses - but the tunnel does not come up : (
On the CISCO Router are running tunnels with crypto map - it works fine to other destinations ! - only the connection with the Mikrotik fails ... First I could need a fourth or fifth hint to a working configuration example someone is working with (live) and I like to try to find out more in the logs if it might fail again.
Someone is working fine with Cisco < > Mikrotik ?
Thanks !!
