Warning message
Remote access to touch 8
May 3rd, 2014
Is there a way to connect to a Touch Panel 8 for remote control?
The issue that I am trying to solve is that the Touch Panel may become unpaired to the C20 codec during a software upgrade and I want a way to "touch" the panel remotely to tell it to re-pair up with the Codec after the upgrade.  These Codec's and Panels are in remote locations with little local technical support.  Want to be able to do the upgrades at night and have the units and panels ready to work in the morning.
Wayne DeNardi Sun, 05/04/2014 - 19:35
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 TelePresence
I don't believe there is any way to remote control, or remotely touch, a touchpanel.
You can "unpair" a panel via the command line, but nothing that I can see to remotely pair one.
