Warning message
Julio Carvajal Sat, 05/03/2014 - 18:57
  • Purple, 4500 points or more
Not sure what you mean but remember that tags only flow over Trunk links,
Now if you want a specific subnet/vlan to be untagged then just make sure it's the native VLAN.
Makes sense?
medbarki1 Sun, 05/04/2014 - 02:06
hello
ok thank you julio,
but can you explain with an example of configurations
regards.
InayathUlla Sharieff Sat, 09/13/2014 - 06:54
  • Cisco Employee,
I am not going to you use your diagram just explaining here:
Below explanation in layman term:
1)
Access Port---Means untagged port.
Int f0/1
Switchport mode access
Switchport access vlan 10 >> Which means the port is part of vlan 10 and its in untagged state.
Trunk Port--Means Tagged Port:
Int G0/1
Switchport mode trunk
Switchport trunk allowed vlan 10 >>> Which means that if the trunk is up and working fine the packet going out of this interface would have tag on it with vlan 10. Trunk port - frames will be sent with VLAN tag. If only one VLAN allowed, then only frames with allowed vlan tag will be sent
Switchport trunk allowed native vlan 20  >>> Which means that the packet though it is passing through the trunk port but still it would not be tagged.
2)
Another way of explaining this would be:
A trunk allows pretagged packets to passthrough without changing the tag while an access port takes the packets it receives and retags them.
Ex.  To setup a trunk to allows all vlans(pretagged) traffic to flow to and from it
int fa0/0
switchport mode trunk <------ explicitly making this port a trunk rather than allowing it to "negotiate" its role (only command needed)
Ex.  To setup an access port and telling to tag the traffic as vlan 10
int f0/1
switchport mode access <----- explicitly making this an access port rather than allowing it to "negotiate" its role
switchport access vlan 10  <--------- tell this interface to tag any traffic entering the port as vlan 10
