Warning message
CME Dial Peer Stripping First Digit
Answered Question
May 5th, 2014
          I have 2 site SITE A with CUCM 9.2 with the extension numbers 9XXX and I wan to call from SITE B which has CME . To do this I created Inter cluster trunk on the CUCM9.0 and created dial peer on CME  to receive the call and works perfectly.
The CME site users uses digit 9 to take external line to call on mobile or land lines.
When I make a dial peer with destination pattern 9... it works but they are not able to take external line since 9 is already used.  I want a dial peer like this listed below
destination pattern 29xxx where it should strip first digit 2 and send 9xxx.
Correct Answer by Manish Prasad about 3 years 3 months ago
voice translation-rule 1
 rule 1 /^2\(9...$\)/ /\1/
voice translation-profile Strip2
 translate called 1
dial-peer voice xxx voip
 translation-profile outgoing Strip2
Manish
Overall Rating: 4 (2 ratings)
Correct Answer
Manish Prasad Mon, 05/05/2014 - 00:32
 translate called 1
Manish
cigalahgroup Mon, 05/05/2014 - 01:13
Thanks Manish will it work like this
voice translation-rule 9000
 translate called 9000
dial-peer voice 9001 voip
destination-pattern 2[9]...
session target ipv4:10.202.0.3
dtmf-relay h245-alphanumeric
 no vad
Suresh Hudda Mon, 05/05/2014 - 02:41
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
yes, it will work.
Suresh
Rakesh K Tue, 05/06/2014 - 01:06
Hi Mansih,
I was just thinking will this work or not, Could please let me know.
dial-peer voice 123 voip
destination pattern 29XXX
digit forward 4
session target ipv4 x.x.x.x
Thanks in advance
Manish Prasad Tue, 05/06/2014 - 01:35
I haven't tried forward digit on VOIP dial-peer because translation profile is more powerful tool to manage digits.
If it something new to new IOS then it will works same as on POTS dial-peer and Yes it will forward only last four digits.
Manish
