05-05-2014 02:21 AM - edited 03-01-2019 11:39 AM
My UCS FI are installed with Ver 2.2.1C. When I reload FI-A or FI-B my Service Profile vEth or vHBA are in an unknown state or error disabled. This is viewed in the Service Profile VIF Paths Tab.
I have to reset the IOM Module to clear the fault. The issue can be random. Out of 6 Chassis's 4 of them were affected.
Any suggestions would be appreciated.
thanks
Ian.
05-05-2014 04:15 AM
Ian,
At a glance it could be related to https://tools.cisco.com/bugsearch/bug/CSCum72151/?reffering_site=dumpcr
this should be fixed in 2.2.1d
You might want to check with TAC.
M.
05-06-2014 10:49 AM
Marcin,
I will upgrade to V2.2(1D) and re-test a failover.
Ian.
05-05-2014 06:15 AM
Hi Ian
What is your motivation to reload FI ? is this just a test, to simulate the loss of a FI;
My question would be: is this also happening, if you diassociate / reassociate a SP ?
05-06-2014 10:47 AM
The reload was to test the loss of a FI prior to going into the production environment. A disassociate/reassociate of a SP made no difference.
I plan to upgrade to V2.2(1D) and re-test again tomorrow.
