Warning message
CUCM 9.1 - CDR formula
Answered Question
May 5th, 2014
I have downloaded CDR dumps and CDR management dumps.  When I try to apply the formula  to convert date/time to a proper formate, I am getting incorrect time.
When I veiw the call from CUCM CDR I can see the correct time.  The Original Call Leg ID matches the one in the dump.  So I have located the correct call, CUCM shows 6:00 pm, which is correct.  When I apply the formula it shows 9:00 pm.  Date is correct on both.
Formula being used is; A1/86400+DATE(1970,1,1). the number given in the dump is 1399064442.
Call came in at 6:00 pm.  Cannot account for the 3 hour difference.
Any insight would be appreciated.
AK
Correct Answer by Jaime Valencia about 3 years 3 months ago
Have you considered that time is GMT?? Any offset needs to be adjusted manually when doing the conversion.
CAR does this for you in the reports.
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 05/05/2014 - 09:13
  • Cisco Employee,
  • Hall of Fame,
    2011
Ayaz Khan Thu, 05/08/2014 - 13:06
thanks Jaime,
It was using GMT, I used the following formula and the correct time was generated;
=(E3/86400)+25569+(-3/24)
AK
