Warning message
Rasika Nayanajith Tue, 05/06/2014 - 22:17
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Which prime version are you using ?
Here is what Prime 2.1 user guide says
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-1/user/guide/pi_ug/alarms.html#pgfId-1054572
Prime Infrastructure logs all emergency, alert, and critical messages generated by all devices that are managed by Prime Infrastructure.
Prime Infrastructure also logs all SNMP messages and syslogs it receives. To view syslogs, choose Operate > Alarms & Events , then click the Syslogs tab.
Syslog Predefined Filters
Prime Infrastructure uses the following syslog filters:
Severity 0 and 1
Severity 2
Environmental Monitor
Memory Allocation Failure
Catalyst Integrated Security Features
Cisco IOS Firewall Denial of Service
Read this thread as well, it talks about tweak this setting, but it could leads to fill up your prime disk space quickly.
https://supportforums.cisco.com/discussion/11645481/prime-infrastructure-12-syslog
Rasika
**** Pls rate all useful responses ****
Abhishek Abhishek Wed, 05/28/2014 - 15:52
  • Gold, 750 points or more
Changing Syslog Logging Options
Syslog option allows you to enable the sending of syslog messages relating to the internal operation of Prime Infrastructure, to a third party syslog server. It does not enable the relaying of syslog messages received from network devices, to a third party syslog server.
Step 1 Choose Administration > Logging , then click Syslog Logging Options .
Step 2 Select the Enable Syslog check box to enable sending of Prime Infrastructure system log messages.
Step 3 Configure the IP address of Syslog Server to which the system log message have to be sent.
Step 4 Choose the Syslog Facility. You can choose any of the eight local use facilities for sending syslog messages. The local use facilities are not reserved and are available for general use.
Step 5 Click Save .
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
