Question about native vlan
May 6th, 2014
When using "LAN Uplinks Manager"  to configure vlan, these is a "native vlan" checkbox. My question is what is the different by check or uncheck it?
When adding more vNIC for a server, and use the two more added vNICs for VMware ESXi software iscsi config.
Modify vlan for the added vNIC, after select vlan, and there is also "native vlan" option. My question is what is the different by check or uncheck it for a vNIC.
Are there any relationship between the "native vlan" setting in vlan manager and the one in vNIC setting?
Thanks.
