Warning message
Prime Assurance
Answered Question
May 7th, 2014
Is the assurance license needed to run Netflow and NBAR in PI2.0 ?
Correct Answer by Marvin Rhoads about 3 years 3 months ago
Yes.
Technically Prime Infrastructure Assurance is performing NetFlow monitoring. NBAR is supported via deployment templates and is used on the collectors to identify applications which can then be analyzed with PI Assurance AVC and Medianet functions.
Not without the TAC licensing team generating you a temporary license. You might be able to get your partner (if your're working with one) or, if you're a partner, have your CSE get you a Not for Resale (NFR) evaluation license.
If you're just looking to kick the tires you can also just (re)build a server and start the clock fresh.
Overall Rating: 5 (2 ratings)
Correct Answer
Marvin Rhoads Wed, 05/07/2014 - 08:13
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Yes.
SpongeRob Wed, 05/07/2014 - 06:25
Thanks Marvin.
Do you think not having taken advantage of the 60 day assurance trial window following the initial installation, that it could be enabled again ?
Correct Answer
  • Hall of Fame,
