EX-series upgraded but not the Touch 8
Answered Question
May 8th, 2014
I have upgraded all EX-Series at the customer to TC7.1.1.
Now, by chance, I've noticed that some of them didn't upgrade the Touch, sitll running on TC7.0.2.
Anyone an idea?
kind regards,
Correct Answer by heathrw about 3 years 3 months ago
If the reboot does not help you can do a factory defaults on the Touch Panel
Instructions here:
https://supportforums.cisco.com/video/11930611/resetting-cisco-teleprese...
Correct Answer by Wayne DeNardi about 3 years 3 months ago
A reboot should trigger the upgrade on the touch connected to the codecs.  Have you checked that the codecs for those 10 have actually upgraded to TC7.1.1?
Overall Rating: 5 (3 ratings)
Martin Koch Thu, 05/08/2014 - 18:14
  • Red, 2250 points or more
How did you check that? Did you try a reboot of theendpoint, are you sure its the touchpanel
and not the system itself which is still on the wrong software?
Please do a xstatus on the endpoint and paste the output of the following commands:
xstat // experimental Peripherals ConnectedDevice
xstat // SystemUnit Software Version
this is what I see here
*s SystemUnit Software Version: "TC7.1.1.168aadf"
*s Experimental Peripherals ConnectedDevice 1001 HardwareInfo: "101654-3"
*s Experimental Peripherals ConnectedDevice 1001 ID: "<mac>"
*s Experimental Peripherals ConnectedDevice 1001 Name: "Cisco TelePresence Touch"
*s Experimental Peripherals ConnectedDevice 1001 SoftwareInfo: "TT7.1.1.168aadf"
*s Experimental Peripherals ConnectedDevice 1001 Status: Connected
*s Experimental Peripherals ConnectedDevice 1001 Type: TouchPanel
*s Experimental Peripherals ConnectedDevice 1001 UpgradeStatus: None
As you see the touchpanel does not have TC anyhow, it is TT
Hans-Werner Prinz Fri, 05/09/2014 - 13:19
Hi Martin,
Correct, It's TT.
But still, from 10 devices, when i click on 'Configuration' -> 'Peripherals'
two of them show the SW-Version on the Touch is still TT7.0.2.xx
...and i have around 100 EX-Series at that customer...
Would maybe a reboot be enough to initiate an upgrade of the Touch?
- or do i really need to try to do a second upgrade on those boxes.
---i didn't check any other C20/SX20 with touch 8 so far, except the one in my customers lab...
/hans
Correct Answer
Wayne DeNardi Fri, 05/09/2014 - 17:30
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 TelePresence
