Warning message
ACS 5.4 excessive load times for log collector viewing
May 8th, 2014
Greetings again;
Have been getting alarms of database failures on the dashboard for ACS 5.4.0.46.2. From what I've gleaned on here, you go to the log collector and see what the errors are by going to Monitoring Configuration>System Operations>Log Collector.
However, it starts to load, and the progress bar gets to about 40-45%, then stops. It's been almost a half hour, and no change.
Anyone know of a solution?
