1522 Outdoor Access Point Clarification
Answered Question
May 9th, 2014
Dear Folks,
One of our client requires Outdoor Access Points across the campus, UTP outdoor cable would be provided.
I would like to clarify the following points
1. Does the Standard model 1522 Access Point support POE that can take direct from POE Switch or is POE injector mandatory ?
2. Is mounting kit included or ordered extra ?
Appreciate your kind help and support .
SID
Correct Answer by Leo Laohoo about 3 years 3 months ago
Outdoor APs require injectors.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Fri, 05/09/2014 - 01:07
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
ciscokid7181 Fri, 05/09/2014 - 01:23
If i purchase this unit, does it come along with the power cable and adaptor ? As i dont see in the configurator / datasheet , i assume it is built in .
SID
Scott Fella Fri, 05/09/2014 - 09:02
  • Hall of Fame,
    2017 Wireless
You can find the part numbers here:
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1130-a...
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
Scott Fella Fri, 05/09/2014 - 09:04
  • Hall of Fame,
    2017 Wireless
Typically you would hard wire the power to the units that are considered MAP's, or the AC adapter.  The RAP's typically would have a power injector to power that unit up.
Scotty
