Warning message
How to restore a Cisco 1841
May 9th, 2014
Hi guys,
to reset a cisco 1841 tofactory settings, we enter in rommon interface and by mistake we used confreg 0x024 instead of 0x2142.
After the reboot I'm not able to read the carachters, looks like to be on wrong serial speed, but it isn't.
Do I need to trash it ?
SANTHOSHKUMAR S... Fri, 05/09/2014 - 07:23
  • Silver, 250 points or more
Hi ,
 Try with different console speed . You should be able to see the characters .
http://www.cisco.com/c/en/us/td/docs/routers/access/1800/1841/software/configuration/guide/sw/b_creg.html#wp40498
Table 4 Console Line Speed Configuration Register Bit Combinations
Bit 5
Bit 11
Bit 12
Console Line Speed (baud)
Sandy
Related Content
