Warning message
ipv6 Configuration
May 10th, 2014
i have 3 layer3 switchs connected, each of them have 6 layer2 switchs connected.
i need to set a ipv6 addres to each gateway interface in the packet tracer. however i could not do it.
how do i do this in the packet tracer?
davrojas Tue, 05/13/2014 - 06:55
  • Bronze, 100 points or more
Hello santoshluiz,
Did you enable first ipv6 routing globaly with the command: ipv6 unicast-routing?
D.a.v.i-d
jesper_petersen Fri, 03/13/2015 - 02:33
Hello santoshluiz
Depending on what types of layer3 switches you have, you might need to do a sdm prefer change.
This is true for the 3560/3750's and the like....
Try with "sdm prefer dual-ipv4-and-ipv6 default" - you will need to reboot the switch before the changes are applied. Some switches do not show any ipv6 related commands before you change the sdm prefer.
mandavid Wed, 03/02/2016 - 09:24
  • Cisco Employee,
Hello Santoshluiz
In order to do this in packet tracer you would have to enable ipv6 routing on your layer 3 switch and use the no switchport command to be able to specify an ipv6 address on that interface.
I hope this helps!
Related Content
