Warning message
About C3850 Wireless Multicast issue
May 12th, 2014
Hello
     i'm testing for catalyst 3850 wireless multicast, and i've tried several configurations but it's always fault. I took a pc with the wired as the multicast video source, and another pc as the receiver with wireless, the two pc in the same vlan, for example, vlan 10.  the followed is the detail configuration about 3850.
<omitted>
ip routing
ip multicast-routing
ip multicast auto-enable
ip igmp snooping querier
interface Vlan6                        ------The Access Point  Vlan and it's the same vlan as wireless management vlan
 description TO-Wireless_AP
 ip address 192.168.6.254 255.255.255.0
 ip pim sparse-dense-mode
interface Vlan10                ----The video source vlan and the wireless receiver client vlan.
 description TO-EXSi
 ip address 192.168.10.254 255.255.255.0
wireless mobility controller
wireless management interface Vlan6
wireless multicast
wlan VideoStream 3 VideoStream
 client vlan 10
 no security wpa
 no security wpa akm dot1x
 no security wpa wpa2
 no security wpa wpa2 ciphers aes
 no shutdown
ap capwap multicast 239.100.1.1
<omitted>
The video multicast group address is 239.100.1.1, here are some show command results.
show ip mroute
(*, 239.100.1.1), 00:01:13/stopped, RP 10.1.1.1, flags: SPF
  Incoming interface: GigabitEthernet1/0/1, RPF nbr 10.0.0.2
  Outgoing interface list: Null
(192.168.10.6, 239.100.1.1), 00:01:13/00:01:46, flags: PFT
  Incoming interface: Vlan10, RPF nbr 0.0.0.0
(*, 239.255.255.250), 01:21:59/00:02:05, RP 10.1.1.1, flags: SJC
    Vlan5, Forward/Sparse-Dense, 01:21:59/00:02:05
(*, 224.0.1.40), 01:21:59/00:02:02, RP 10.1.1.1, flags: SJCL
    Vlan5, Forward/Sparse-Dense, 01:21:59/00:02:02
show ip igmp snooping wireless mgid
Total number of L2-MGIDs    = 3
Total number of MCAST MGIDs = 0
 Wireless multicast is Enabled in the system
 Vlan     bcast   nonip-mcast   mcast    mDNS-br  mgid    Stdby Flags
 1     Disabled   Disabled   Enabled    Enabled    Disabled  0:0:1:0
 5     Disabled   Disabled   Enabled    Enabled    Disabled  0:0:1:0
 6     Disabled   Disabled   Enabled    Enabled    Disabled  0:0:1:0
 7     Disabled   Disabled   Enabled    Enabled    Enabled   0:0:1:0
 8     Disabled   Disabled   Enabled    Enabled    Enabled   0:0:1:0
 9     Disabled   Disabled   Enabled    Enabled    Disabled  0:0:1:0
 10    Disabled   Disabled   Enabled    Enabled    Enabled   0:0:1:0
 1002  Enabled    Enabled    Enabled    Enabled    Disabled  0:0:1:0
 1003  Enabled    Enabled    Enabled    Enabled    Disabled  0:0:1:0
 1004  Enabled    Enabled    Enabled    Enabled    Disabled  0:0:1:0
 1005  Enabled    Enabled    Enabled    Enabled    Disabled  0:0:1:0
Index  MGID                  (S, G, V)
The C3850 software version is Version 03.03.03SE RELEASE SOFTWARE (fc2), and i've tried the Version 03.02.02SE, it's the same result. if the multicast not worked, i can't do the Videostream function demo next step.
