Warning message
Policy Based Routing 4500X
May 12th, 2014
Hi all,
I have a problem regarding PBR on a Cisco 4500-X. I`d like to configure a source routing from the IP address 192.168.217.52 over the address 192.168.211.6 instead of the "normal" default route (192.168.200.50). Therefore I configured the following:
access-list 101 permit ip host 192.168.217.52 any
 route-map gold permit 10
 match ip address 101
 set ip next-hop 192.168.211.6
interface Vlan217
 ip address 192.168.217.1 255.255.255.0
 no ip redirects
 no ip proxy-arp
 ip policy route-map gold
Unfortunately it does not work. If I do a traceroute I can observe that still the default route is active:
C:\Users\schoerlf>tracert -d 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
  1     2 ms     8 ms     2 ms  192.168.217.1
  2     1 ms     1 ms     1 ms  192.168.200.50
  3     2 ms     2 ms     2 ms  157.161.177.70
  4     4 ms     3 ms     3 ms  157.161.253.237
  5    34 ms    28 ms    27 ms  157.161.197.252
  6     2 ms     2 ms    12 ms  157.161.254.5
  7     4 ms     3 ms     4 ms  91.206.52.74
  8    10 ms     9 ms     9 ms  72.14.232.120
  9     9 ms     9 ms     9 ms  72.14.234.235
 10     9 ms     9 ms     9 ms  209.85.254.118
 11     *        *        *     Request timed out.
 12     9 ms     9 ms     9 ms  8.8.8.8
T&R
Frank
