Warning message
Choosing between PRI's
May 12th, 2014
Hey guys,
Have a two port e1 card and terminating two pri's on it. One with range 1234xxxx and one with 6789xxxx from two different providers. I have cucm 9. Can I route calls to either one of the pri's ? I need to dial 0 to get into the 1st one and dial 9 to go thru the 2nd pri.
Suresh Hudda Mon, 05/12/2014 - 22:55
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Yes, It is possible.
Suresh
Suresh Hudda Mon, 05/12/2014 - 23:02
    2017 IP Telephony
how voice gateway has configured, is it MGCP or H323 ?
Suresh Hudda Mon, 05/12/2014 - 23:26
    2017 IP Telephony
In this scenario you need to create two route patterns in CUCM..
One is; 0.T (or you modify it more specifically as per your requirement) and assign 1st E1 port under "Gateway/route list" and remove 0 by selecting pre-dot under discard digit.
2nd route pattern: is 9.T and assign 2nd E1 port under "Gateway/route list"  and remove 9 by selecting pre-dot under discard digit.
Note: You can configure route group and route list if requirement.
Suresh
