UCS network card
Answered Question
May 14th, 2014
hello every one
i ask if i could disactivate the 1 st network card because I'm installing a CUCM registrerd with the 2nd card.
if so how i can do it.
Best Regards
Correct Answer by Jaime Valencia about 3 years 3 months ago
Assuming you won't have redundancy, plug NIC 1 and have licensing rehost your license.
Overall Rating: 5 (2 ratings)
Jaime Valencia Wed, 05/14/2014 - 09:17
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM knows nothing about NICs when installed on UCS, that goes down to your ESXi config and your vSwitch. Also, CUCM on ESXi only uses ONE vNIC, not even sure what you mean it's registered with a 2nd card.
youssef.erraki Wed, 05/14/2014 - 11:17
Hi Jaime
thank you for your reply,
for info My CUCM install on UCS7816, physical installation, when i install the server ofr the first time it was used the 2nd NIC, I try te reboot the server, this later move to 1st NIC, and that's impact the license file (CUCM 8.5), my question is if how I could change to be 2nd NIC as default network card.
Best Regards
youssef
Jaime Valencia Wed, 05/14/2014 - 11:21
  • Cisco Employee,
  • Hall of Fame,
    2011
You DO NOT have a UCS, that's an MCS
MCS 7816, NOT UCS 7816
You don't choose which card to use, either you use the 1st NIC if not redundancy is configured, or you plug both if you enabled redundancy. There's no option to choose the 2nd NIC as the primary NIC, and the only one that will be plugged.
youssef.erraki Wed, 05/14/2014 - 11:50
Hey jaime
yes you are right, I use MCS 7800 series, my problem is the license file was generated with the 2nd NIC that's mean that if I plug to 1st NIC the server will be joined on LAN otherwise the CUCM show me that's a error ceritifact not valid (the registation of the license was done on 2nd NIC), actually i try to plug a cable on 2nd but it was not work.
Best Regards
Correct Answer
Jaime Valencia Wed, 05/14/2014 - 13:00
  • Cisco Employee,
  • Hall of Fame,
    2011
