New FCoE Implementation
Hi All
We are designing a new fcoe implementation with HP VC 10/10D (dual hop fcoe). It connects to our nexus 5596. I had a few questions on this:
1) Existing 5596 also has a lot of native fc connections . 5596 connects to brocade on NPV. native fc connections are on vsan 10. Should we configure a new vsan for fcoe (to map it to a vlan), or is it ok to use the same vsan ? what is the best practice ?
2) We have the fc_features license, and have enabled fcoe feature. Do we need fcoe NPV license ? I see in cisco website that there are 2 ways to configure fcoe, and the 2nd way is using fcoe npv . when is fcoe npv used?
3) we enabled feature fcoe, but we dont see show commands like "show flogi database" , "show fcdomain" etc .. do we need fcoe npv license for these to work ?
Thanks in advance.
Raj
nipathak
3 )we enabled feature fcoe, but we dont see show commands like "show flogi database" , "show fcdomain" etc .. do we need fcoe npv license for these to work ?
ans ) when you switches are in NPV mode then you can type
sh npv flogi to check the flogi database.
2) existing 5596 also has a lot of native fc connections . 5596 connects to brocade on NPV. native fc connections are on vsan 10. Should we configure a new vsan for fcoe (to map it to a vlan), or is it ok to use the same vsan ? what is the best practice ?
for vsa mapping you can create valn and map it to vsan
for example.  vlan 2002
fcoe vsan 2002 this enable vlan to vsan mapping .
