Warning message
ESXi upgrade to 5.5.1a on UCS C210 M2 Servers
May 15th, 2014
I have three UCS C210 M2 servers running my CUCM 8.6.2, Unity Connection, and Contact Center Express. My VM administrator would like to upgrade our ESXi host to the latest version (5.5.1a) to correct the heartbleed vulnerability. I can't seem to find any documentation that goes higher than ESXi 5.1. My question is has anyone upgraded to ESXi 5.5.1a on a similar platform and if so were there any issues that needed to be addressed?
Overall Rating: 5 (2 ratings)
Ramond Brothers Sun, 05/25/2014 - 16:10
I first upgraded the CIMC from version 1.3(2j) to 1.4(3v). Despite the Cisco compatibility document, talking to Cisco TAC support, I was able to upgrade our 2 UCS C210 M2 from ESXi 4.1 directly to ESXi 5.5 1a. Our current CUCM is version 8.6.(2), UCCX 9.0(2) all running fine on 2 UCS C210 M2 and ESXi 5.5 1a. You can download the Cisco custom ISO from this URL https://my.vmware.com/web/vmware/details?productId=353&downloadGroup=OEM-ESXI55GA-CISCO. I am planning to upgrade our CUCM from version 8.6(2) to 10x as well as UCCX 9.0(2) to 10x.
Jaime Valencia Sun, 05/25/2014 - 18:18
  • Cisco Employee,
  • Hall of Fame,
    2011
I assume you know that your environment will not be supported by Cisco, right??
econstantinou Mon, 06/23/2014 - 13:37
I am planning to upgrade our 3x UCS C210 M2 from ESXi 4.1 to 5.5. I would like to ask if a license is required after upgrade.
regards & thanks
Ramond Brothers Mon, 06/23/2014 - 14:01
You will need new VMware licenses when you upgrade ESXi 4.1 to 5.5 (you will have 60 days to put the license).
