Nexus 7K object Track
May 16th, 2014
i have two nexus switches each switch has 10g module and 1g module, i enable vPC peer link over 10g module and 1g for access switch,
if the nexus switch-1 is primary, and the 10g module failed , the vPC member in the secondary switch will be shutdown, to avoid this issue i read we can use Object Track to let the secondary switch will be primary my query is :
1. during conversion to be secondary primary there is no any interruption traffic.
2. assume i have two devices each device has one leg connected to the secondary switch, and the peer-link went down and peer keepalive up these two devices can be communicate between each other.
