Warning message
Internal LAN - Port Channels shows none.
May 17th, 2014
When I go to the UCSM LAN tab under Internal LAN, I do not see any port channels there. why is that?
but if I log into the ucsm cli,
I see some
 sh port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
21    Po21(SU)    Eth      LACP      Eth1/17(P)   Eth1/18(P)   Eth1/19(P)
                                     Eth1/20(P)
1286  Po1286(SU)  Eth      NONE      Eth2/1/9(P)  Eth2/1/10(P)  Eth2/1/11(P)
                                     Eth2/1/12(P)
1293  Po1293(SU)  Eth      NONE      Eth1/1/9(P)  Eth1/1/10(P)  Eth1/1/11(P)
                                     Eth1/1/12(P)
1298  Po1298(SU)  Eth      NONE      Eth1/1/5(P)  Eth1/1/6(P)  Eth1/1/7(P)
                                     Eth1/1/8(P)
1300  Po1300(SU)  Eth      NONE      Eth2/1/5(P)  Eth2/1/6(P)  Eth2/1/7(P)
                                     Eth2/1/8(P)
1306  Po1306(SU)  Eth      NONE      Eth1/1/17(P)  Eth1/1/18(P)  Eth1/1/19(P)
                                     Eth1/1/20(P)
1308  Po1308(SU)  Eth      NONE      Eth2/1/17(P)  Eth2/1/18(P)  Eth2/1/19(P)
                                     Eth2/1/20(P)
1311  Po1311(SU)  Eth      NONE      Eth2/1/13(P)  Eth2/1/14(P)  Eth2/1/15(P)
                                     Eth2/1/16(P)
1312  Po1312(SU)  Eth      NONE      Eth1/1/13(P)  Eth1/1/14(P)  Eth1/1/15(P)
                                     Eth1/1/16(P)
1315  Po1315(SU)  Eth      NONE      Eth2/1/21(P)  Eth2/1/23(P)
1317  Po1317(SU)  Eth      NONE      Eth1/1/21(P)  Eth1/1/23(P)
Keny Perez Tue, 05/20/2014 - 21:44
  • Blue, 1500 points or more
I am pretty sure you are looking at the internal PC created by the 2nd Gen hardware... what Adapters, IOMs and FIs do you have?
-Kenny
Keny Perez Fri, 05/23/2014 - 06:25
Tony,
All port-channels you see with "Protocol = None" are the internal PCs, the uplink port channels will show up as "Protocol = LACP" , see below:
F340-22-25-CR-FI-6248-A(nxos)# sh port-channel summary
      Channel
1     Po1(SD)     Eth      LACP      Eth1/17(I)   Eth1/18(D)
1289  Po1289(SU)  Eth      NONE      Eth1/1/29(P)  Eth1/1/30(P)  Eth1/1/31(P)
                                     Eth1/1/32(P)
1290  Po1290(SU)  Eth      NONE      Eth1/1/21(P)  Eth1/1/23(P)
1291  Po1291(SU)  Eth      NONE      Eth1/1/25(P)  Eth1/1/26(P)  Eth1/1/27(P)
                                     Eth1/1/28(P)
To show you, I created a PC with the ports 17 & 18 (but I have nothing else configured there or in the upstream switch, that is the reason why you see them in (I) and (D)
I hope that helps.
-Kenny
