05-18-2014 09:07 AM - edited 03-17-2019 04:10 PM
Hi All UC Experts,
I'm using the IM&P 9.1.1, which integrated with the CUCM 9.1.2, that is working fine on my environment. All Jabber functions is working, including the VPN-less Jabber.
Suddenly, some VPN-less Jabber cannot login normally. I checked the IM&P, that showed the error as (System > CUCM Publisher) "Not connected (check valid AXL username/password credentials)" .
Actually, my CUCM Subscriber was going down already, but is is not related. It is because it would not show the error when the CUCM subscriber was down.
I tried to change the AXL user to the others, but fail ...
Any idea for that? Thanks!
05-18-2014 10:29 AM
Are you absolutely sure you're using the right user, and with the right roles???
05-18-2014 06:11 PM
Sure, I added the "Standard AXL API Access" & "Standard CTI Enabled"
01-11-2016 05:39 AM
hello,
did you found the problem?
01-11-2016 02:39 PM
Can you try log into https://<cucm_ip>/axl/ ?
01-12-2016 05:08 AM
I have found the solution with tac, he accesed to root with root user. everything was all ok on cucm and imp.
