Warning message
Dear fellows, Kindly I am facing issue when ruing a 3G SIM card in a Cisco "C819HG-4G-G-K9" the profile is flapping between “
May 20th, 2014
Dear fellows,
Kindly I am facing issue when ruing a 3G SIM card from Etisalat UAE in a Cisco "C819HG-4G-G-K9" the profile is flapping between “ACTIVE” and “INACTIVE” also I am getting below error messages:
Running Config:
chat-script hspaq "" "AT!SCACT=1,1" TIMEOUT 60
interface Cellular0
 ip address 192.168.100.216 255.255.240.0
 ip access-group SITE-TO-SITE in
 ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer string hspaq
 dialer-group 1
 async mode interactive
line 3
 exec-timeout 0 0
 script dialer hspaq >>>> But when I issue the script dialer direct-ip command here the profile stay active but interface ip address                                             will be spoofing and not ping able.
login
 modem InOut
 no exec
 transport input all
 transport output all
 rxspeed 100000000
 txspeed 50000000
mss-test-ra#
Error Message:
*May 20 11:31:18.067: CHAT3: Attempting async line dialer script
*May 20 11:31:18.067: CHAT3: Dialing using Modem script: hspaq & System script: none
*May 20 11:31:18.071: CHAT3: process started
*May 20 11:31:18.071: CHAT3: Asserting DTR
*May 20 11:31:18.071: CHAT3: Chat script hspaq started
*May 20 11:31:18.071: CHAT3: Sending string: AT!SCACT=1,1
*May 20 11:31:18.071: CHAT3: Chat script hspaq finished, status = Success
*May 20 11:31:20.071: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*May 20 11:31:21.071: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to up
*May 20 11:33:22.071: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
*May 20 11:33:23.071: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to down
*May 20 11:33:27.071: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
*May 20 11:33:38.071: CHAT3: Attempting async line dialer script
*May 20 11:33:38.071: CHAT3: Dialing using Modem script: hspaq & System script: none
*May 20 11:33:38.075: CHAT3: process started
*May 20 11:33:38.075: CHAT3: Asserting DTR
*May 20 11:33:38.075: CHAT3: Chat script hspaq started
*May 20 11:33:38.075: CHAT3: Sending string: AT!SCACT=1,1
*May 20 11:33:38.075: CHAT3: Chat script hspaq finished, status = Success
*May 20 11:33:40.075: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*May 20 11:33:41.075: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to up
*May 20 11:35:42.075: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
*May 20 11:35:43.075: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to down
*May 20 11:35:47.075: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
mss-test-ra#sh cellular 0 profile
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = mss.net
Authentication = CHAP
Username: cisco
Password: cisco
  * - Default profile
 ** - LTE attach profile
Configured default profile for active SIM 0 is profile 1.
I will appreciate if any one can share a working configuration.
gihanucsc Tue, 05/20/2014 - 05:25
Are you using chap username password for this connection?
Then try creating a dialer interface with ppp authentication instead having slip on the cellular interface.
Try something like below:
interface Cellular0
 no ip address
 encapsulation slip
 dialer in-band
 dialer pool-member 1
interface Dialer1
 ip address negotiated
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 0
 dialer string INTERNET
 dialer persistent
ip route 0.0.0.0 0.0.0.0 Dialer1
line 3
 script dialer INTERNET
Your chat script is working fine and check what you get on the debug output:
debug chat
debug ppp authentication
debug dialer
1mody1mody Tue, 05/20/2014 - 05:52
Dear gihanucsc,
thank you for your reply.
I have applied the above configuration, but still the profile is not coming up.
Kindly have a look to the below debug output.
Running Config:
mss-test-ra#sh run | in ip route
mss-test-ra#
mss-test-ra#sh run int cell 0
Building configuration...
Current configuration : 199 bytes
interface Cellular0
no ip address
encapsulation slip
dialer in-band
dialer-group 1
end
mss-test-ra#
mss-test-ra#sh run int dialer 1
Current configuration : 292 bytes
interface Dialer1
encapsulation ppp
dialer pool 1
dialer string hspaq
dialer persistent
dialer-group 1
no ppp lcp fast-start
ppp chap password 0 cisco
ppp ipcp dns request
end
mss-test-ra#
mss-test-ra#sh run | s line 3
line 3
exec-timeout 0 0
script dialer hspaq
login
modem InOut
no exec
transport input all
rxspeed 100000000
txspeed 50000000
mss-test-ra#
Debug Message:
*May 20 12:40:20.363: CHAT3: process started
*May 20 12:40:20.363: CHAT3: Asserting DTR
*May 20 12:40:20.363: CHAT3: Chat script hspaq started
*May 20 12:40:20.363: CHAT3: Sending string: AT!SCACT=1,1
*May 20 12:40:20.363: CHAT3: Chat script hspaq finished, status = Success
*May 20 12:40:22.363: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*May 20 12:40:22.363: Ce0 DDR: Dialer statechange to up
*May 20 12:40:22.363: %DIALER-6-BIND: Interface Ce0 bound to profile Di1
*May 20 12:40:22.363: Ce0 DDR: Dialer call has been placed
*May 20 12:40:22.367: Ce0 DDR: dialer protocol up
*May 20 12:40:22.367: Di1 DDR: Persistent Dialer Profile nailed up successfully
*May 20 12:40:23.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to up
mss-test-ra#
mss-test-ra#sh ip int br | in Cel|D
Cellular0 unassigned YES manual up up
Dialer1 unassigned YES manual up up
mss-test-ra#
mss-test-ra#sh cell 0 profile
PDP Type = IPv4
Username: mss-test-ra
Password: cisco
* - Default profile
gihanucsc Tue, 05/20/2014 - 22:43
Try the the below:
interface Cellular0
no ip address
encapsulation slip
dialer in-band
no dialer-group 1
end
mss-test-ra#
interface Dialer1
encapsulation ppp
dialer pool 1
dialer string hspaq
dialer persistent
no dialer-group 1
no ppp chap password 0 cisco
end
trycraeting the cellular profile with the chap info
cellular 0  gsm profile create 1 ipv4 chap '' ''
then have debug ppp authentication
gointshutseewhat to  cellular 0 and shutdown/ no to retry the dial.. errors you're getting
