Warning message
CME Translation Rule Reject Not Working
Answered Question
May 20th, 2014
I've been working with translation rules in an effort to block toll fraud number such as 976.......
My "reject" rules aren't working so I stepped back to a simple proof of concept to affirm my understanding.
Goal, use a reject rule to prevent Ext 100 from dialing Ext 219.
However, even with the config below, I can still call Ext 219 from Ext 100, the call goes through and I can't understand why.
I'm sure I'm missing something obvious, but it's escaping me.
I'd appreciate any pointers.
voice translation-rule 2
 rule 1 reject /219/
voice translation-profile test
 translate called 2
ephone-dn  100  octo-line
 number 100
 pickup-group 1
 label Parish Secretary
 name Parish Secretary
 allow watch
 call-forward max-length 11
 call-forward busy 400
 call-forward noan 400 timeout 16
 corlist incoming chu-user-international
 huntstop channel 4
 translation-profile incoming test
 transfer-mode consult
Sorry, but the "reply" option is not functioning in my browser!!??
I opted for the business hours blocking option, as it was simple, and I needed a quick fix as we cutover the system this weekend giving me no time to test the alternatives, Thx!
Correct Answer by Nathan Compton about 3 years 3 months ago
If you are trying to block calls in CME, here is a much easier way:
telephony-service
 after-hours block pattern 1 91900....... 7-24
 after-hours block pattern 2 91976....... 7-24
Overall Rating: 5 (1 ratings)
Correct Answer
Nathan Compton Tue, 05/20/2014 - 08:02
  • Silver, 250 points or more
telephony-service
Nadeem Ahmed Tue, 05/20/2014 - 13:54
  • Cisco Employee,
Can you please test the rule with below command
# test voice translation-rule 2 219 (and check the output result)
translation-profile incoming test < this has to be outgoing> since you want to prevent extn 100 to dial 219.
Br,
Nadeem
