Warning message
ssh username incorrect
Answered Question
May 20th, 2014
Not sure if it is the packet tracer, but when attempting a packet tracer(1.3.1.3 Packet Tracer - Skills Integration Challenge) for my class the ssh username is saying incorrect this is what am typing: ip domain-name cisco.com crypto key generate rsa 1024 username HQadmin Secret ciscoclass and that is where I think the trouble is at. these are the directions:
· Configure remote management access including IP addressing and SSH: - Domain is cisco.com - User HQadmin with password ciscoclass - Crypto key length of 1024 - SSH version 2, limited to 2 authentication attempts and a 60 second timeout - Clear text passwords should be encrypted. here is the commands entering: ! line vty 0 4 password 7 0822455D0A16 login local transport input ssh line vty 5 15 password 7 0822455D0A16 login local transport input ssh ! ! end
Cnt-Sw(config)#do show ru Cnt-Sw(config)#do show running-config Building configuration...
Current configuration : 2910 bytes ! version 12.2 no service timestamps log datetime msec no service timestamps debug datetime msec service password-encryption ! hostname Cnt-Sw ! ! ! ip ssh version 2 ip ssh authentication-retries 2 ip ssh time-out 60 ip domain-name cisco.com ! username HQadmin secret 5 $1$mERr$UBS6AqpcFjkupAnmSUCGG. ! spanning-tree mode pvst ! interface FastEthernet0/1 switchport access vlan 30 switchport mode access switchport port-security switchport port-security maximum 2 switchport port-security mac-address sticky switchport port-security violation restrict ! interface FastEthernet0/2 switchport access vlan 30 switchport mode access ! interface FastEthernet0/3 switchport access vlan 30 switchport mode access ! interface FastEthernet0/4 switchport access vlan 30 switchport mode access ! interface FastEthernet0/5 switchport access vlan 30 switchport mode access ! interface FastEthernet0/6 switchport access vlan 30 switchport mode access ! interface FastEthernet0/7 switchport access vlan 30 switchport mode access ! interface FastEthernet0/8 switchport access vlan 30 switchport mode access ! interface FastEthernet0/9 switchport access vlan 30 switchport mode access ! interface FastEthernet0/10 switchport access vlan 30 switchport mode access ! interface FastEthernet0/11 switchport access vlan 15 switchport mode access ! interface FastEthernet0/12 switchport access vlan 15 switchport mode access ! interface FastEthernet0/13 switchport access vlan 15 switchport mode access ! interface FastEthernet0/14 switchport access vlan 15 switchport mode access ! interface FastEthernet0/15 switchport access vlan 15 switchport mode access ! interface FastEthernet0/16 switchport access vlan 15 switchport mode access ! interface FastEthernet0/17 switchport access vlan 15 switchport mode access ! interface FastEthernet0/18 switchport access vlan 15 switchport mode access ! interface FastEthernet0/19 switchport access vlan 15 switchport mode access ! interface FastEthernet0/20 switchport access vlan 15 switchport mode access ! interface FastEthernet0/21 switchport mode access switchport port-security switchport port-security maximum 2 switchport port-security mac-address sticky switchport port-security violation restrict shutdown ! interface FastEthernet0/22 ! interface FastEthernet0/23 ! interface FastEthernet0/24 ! interface GigabitEthernet1/1 switchport access vlan 45 switchport trunk native vlan 45 switchport trunk allowed vlan 15,30,45 switchport mode trunk ! interface GigabitEthernet1/2 shutdown ! interface Vlan1 no ip address shutdown ! interface Vlan60 ip address 172.16.15.10 255.255.255.248 ! ip default-gateway 172.16.15.9 ! ! line con 0 password 7 0822455D0A16 login ! line vty 0 4 password 7 0822455D0A16 login local transport input ssh line vty 5 15 password 7 0822455D0A16 login local transport input ssh ! ! end
Cnt-Sw(config)#ip dom Cnt-Sw(config)#ip dom Cnt-Sw(config)#ip doma Cnt-Sw(config)#ip domai Cnt-Sw(config)#ip domain Cnt-Sw(config)#ip domain= Cnt-Sw(config)#ip domain- Cnt-Sw(config)#ip domain-n Cnt-Sw(config)#ip domain-name cisco.com Cnt-Sw(config)#cypr Cnt-Sw(config)#cr Cnt-Sw(config)#crypto k Cnt-Sw(config)#crypto key g Cnt-Sw(config)#crypto key generate r Cnt-Sw(config)#crypto key generate rsa % You already have RSA keys defined named Cnt-Sw.cisco.com . % Do you really want to replace them? [yes/no]: y The name for the keys will be: Cnt-Sw.cisco.com Choose the size of the key modulus in the range of 360 to 2048 for your General Purpose Keys. Choosing a key modulus greater than 512 may take a few minutes.
How many bits in the modulus [512]: 1024 % Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
Cnt-Sw(config)#username HQadmin secret ciscoclass *Mar 1 10:25:38.914: %SSH-5-ENABLED: SSH 2 has been enabled Cnt-Sw(config)#do show running-config Building configuration...
Cnt-Sw(config)#
Correct Answer by SANTHOSHKUMAR S... about 3 years 3 months ago
Hi .
 Looks like already same username is created with different password
no username HQadmin
Not sure this sentence talks about MD5 encryption
if it not accpeting try with plain password
username HQadmin password ciscoclass
Sandy
Overall Rating: 5 (1 ratings)
SANTHOSHKUMAR S... Tue, 05/20/2014 - 17:34
  • Silver, 250 points or more
 If i understand your issue correctly , you are not prompted with username during SSH remote login ?? or the issue is some other .
Sandy
mikemailnit2013 Tue, 05/20/2014 - 17:43
sorry if not clear on this but what am trying to do is setup ssh on a router for the first time by going into the cisco ios and entering into global configuration mode etc...(I am a student and we use a live environment program call packet tracer) the packet tracer is scored on points and one of the points is saying that the username is incorrect..to much to repeat(please see above for the reset of explanation)
Correct Answer
SANTHOSHKUMAR S... Tue, 05/20/2014 - 18:18
Hi .
no username HQadmin
Sandy
mikemailnit2013 Tue, 05/20/2014 - 18:32
hum interesting think I did try that, but let me try that again encase have not.
mikemailnit2013 Tue, 05/20/2014 - 18:39
nope did not work and sorry hit correct answer by mistake.
this is the output and here is an attachment:
Central(config)#username HQadmin pass ciscoclass
ERROR: Can not have both a user password and a user secret.
Please choose one or the other.
Central(config)#no username HQadmin secret ciscoclass
Central(config)#username HQadmin password ciscoclass
SANTHOSHKUMAR S... Tue, 05/20/2014 - 21:16
Hi ,
Only one at a time can be configured for same username , either secret or normal password .
Try only
no username HQadmin Secret ciscoclass
no username HQadmin Password ciscoclass
For an individual user, we can have either a plain text password OR a secret associated with that user, but both may not be configured for a given user.
Sandy
Related Content
