CIsco IOS CME Hacking via E1
May 21st, 2014
Is it possible for someone to make calls via cme running on ios v12.4 using E1 PRI connection?
May 13 2014 15:39:36 00:15:07                          00881842011129           1
May 13 2014 15:50:36 00:05:35                          00881842011146
As log above shows, call was made but cant tell who made the call internally???
May 13 2014 16:28:43 00:00:26 00881842011146                                    2
May 13 2014 16:29:13 00:00:27 00881842011129                                    2
The other log shows originating call as external number but no destination.
2014-05-13 15:54:01    Local7.Notice    172.23.100.1    97068: 097064: *May 13 15:53:36.831 GMT: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:05/13/2014 15:53:03.978,cgn:213,cdn:230,frs:0,fid:65343,fcid:BCC8122FD9DC11E39449EEC1BC9630B,legID:82FC,bguid:BCC8122FD9DC11E39449EEC10BC9630B
2014-05-13 15:55:07    Local7.Info    172.23.100.1    97069: 097065: *May 13 15:54:43.295 GMT: %ISDN-6-DISCONNECT: Interface Serial0/3/0:29  disconnected from 00881842011129 , call lasted 900 seconds
2014-05-13 15:50:24    Local7.Notice    172.23.100.1    97062: 097058: *May 13 15:49:59.860 GMT: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:05/13/2014 15:49:48.388,cgn:,cdn:6800,frs:0,fid:65338,fcid:48834FCED9DC11E38BE100229032E5E0,legID:82F7,bguid:48834FCED9DC11E38BE100229032E5E0
2014-05-13 15:50:48    Local7.Info    172.23.100.1    97063: 097059: *May 13 15:50:23.360 GMT: %ISDN-6-CONNECT: Interface Serial0/3/0:19 is now connected to N/A N/A
2014-05-13 15:51:08    Local7.Info    172.23.100.1    97064: 097060: *May 13 15:50:43.041 GMT: %ISDN-6-CONNECT: Interface Serial0/3/0:30 is now connected to 00881842011146 N/A
The above logs are from syslog.
From firewall side, all SIP, H323 ports are blocked.
