Warning message
Is it possible to set up WebEx meetings via a dial-in Telephone User Interface?
Answered Question
May 21st, 2014
  • Blue, 1500 points or more
As per the title really - is it possible to set up WebEx meetings via an IVR?
I am expecting the answer to be no but just want to check that I have not missed anything.
Correct Answer by Jaime Valencia about 3 years 2 months ago
To the best of my knowledge, the answer is indeed, no.
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 05/21/2014 - 13:45
  • Cisco Employee,
  • Hall of Fame,
    2011
James Hawkins Wed, 05/21/2014 - 13:49
Thanks Jaime,
Appreciate the response
Richard Simmons Wed, 06/11/2014 - 06:38
  • Bronze, 100 points or more
It is actually possible to do this, its called WebEx Personal Conferencing, its available with both the on premise and hosted solution, excluding the free hosted solution.
Log into your WebEx Account and click on the My WebEx Tab
On the left pane click My Profile and scroll down to My Phone Numbers
Enter a PIN, ensuring it’s not a simple sequence as this is not allowed by the system, once you have done this scroll down to the end of the page and click Update.
On the left pane click on Personal Conferencing
Click Add Account – a new window will pop-up - Click Generate and then Close
You will now see your Personal Conferencing details
To start a conference dial either the UK toll free (0800) number or the UK Toll number and enter your Host access code, you will then be prompted to enter your PIN (the one you configured previously). Attendees can then dial in and enter the Attendee access code and they will then join you in the conference.
