Voip with epbax system
Deepak Khemani
I have offices at two location connected via a point to point link. Each location has a epbax system and many pstn phones with extension.
 Is it possible to connect EPBAX to each other  using VoIP. Idea is that i Use the point to pint connection for call betweem these location.
I want to use my existing epbax system with PSTN phones. I dont want to get into purchasing of IP phones.
Please help me asap.
Deepak Khemani
Jaime Valencia
You should post this on sites like voip.org, and not a Cisco specific forum, when this is not Cisco related.
java
if this helps, please rate
