Warning message
3750X Stacking version
May 23rd, 2014
I have simple stack of a 3750X-24T-S and 3750X-24S-S running c3750e-ipbasek9-mz.122-58.SE2.bin. IPBase Licenses are Permanent and Active on both switches.
They will not stack as they are running different stack versions. The "sh platform stack manager all" command shows the 24T-S Stack State Machine View as version 1.46. The same command for the 24S-S Stack State Machine View as version 6.46.
Just received both switches this week. How do I get them to the same stack version so I can form a stack?
Reza Sharifi Fri, 05/23/2014 - 15:11
  • Cisco Designated VIP,
    2017 LAN
Usually when switches will not stack, it means the IOS is different between them.
Can you post "sh ver" from both devices:
Major Version Number Incompatibility Among Switches
Switches with different major Cisco IOS software versions usually have different stack protocol versions. Switches with different major version numbers are incompatible and cannot exist in the same switch stack.
Minor Version Number Incompatibility Among Switches
Switches with the same major version number but with a different minor version number are considered partially compatible. When connected to a switch stack, a partially compatible switch enters version-mismatch (VM) mode and cannot join the stack as a fully functioning member. The software detects the mismatched software and tries to upgrade (or downgrade) the switch in VM mode with the switch stack image or with a tar file image from the switch stack flash memory. The software uses the automatic upgrade (auto-upgrade) and the automatic advise (auto-advise) features. For more information, see the "Understanding Auto-Upgrade and Auto-Advise" section.
To see if there are switches in VM mode, use the show switch user EXEC command. The port LEDs on switches in VM mode stay off. Pressing the Mode button does not change the LED mode.
You can use the boot auto-download-sw global configuration command to specify a URL pathname for the master switch to use to get an image in case of version mismatch.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/so...
Casey Roettger Tue, 01/12/2016 - 23:01
How did you load the IOS?   I use the archive command with tar files and the stack version seems upgrade or downgrade with the ios.
roy_fisher Sun, 08/28/2016 - 10:13
Did you ever fix this ? I have the same issue on a 2960x stack - 1.56 and 7.56 when upgrading to with 15.2(2)E5 from 15.0(2)EX3.
But this is on one stack out of nine - the other 8 are fine.
Roy
Joseph W. Doherty Mon, 08/29/2016 - 05:21
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As mentioned by Reza, stacking versions might differ between different versions of the IOS, so insure all stack members are using the same IOS version and the stacking version should match.
roy_fisher Tue, 08/30/2016 - 07:23
Hi Joseph,
Thanks for your quick response, we're upgrade a stack of two both running 15.0(2)EX3 and using the archive command upgraded to 15.2(2)E5 - we did this on 9 stacks, with just this stack experiencing the problem.
The other 8 stacks all report 1.56 on both switches, it's this one reporting 1.56 and 7.56.
When we rolled back to the previous version both switches worked and both reported 1.55.
Roy
EDITED to add - all switches are the same model - WS-C2960X-48FPS-L
Related Content
