Warning message
CUCM 9.1 - Call-forwarding display
May 23rd, 2014
If phone A calls phone B, and phone B is call forwarding all to a cell phone, phone A's display will show the forwarded cell number.  Is there a way to block this from being displayed on the callers phone?
AK
Manish Prasad Sat, 05/24/2014 - 00:01
From the Service Parameter..
Always Display Original Dialed Number: Required FieldThis parameter determines whether phones always display the number that the caller originally dialed (which may not match the final connected number). If Cisco CallManager routes the call from the originally dialed number to the connected number using a call forwarding directive, a translation pattern, route pattern, a redirection by a CTI application, or other means, this parameter determines whether the connected number or the originally dialed number is exposed. Note that when the Conference List feature is invoked, the connected number always displays regardless of the setting in this parameter. Valid values specify True (display the originally dialed number) or False (display the connected number).
 This is a required field.
 Default:  False
Ayaz Khan Mon, 05/26/2014 - 14:32
Thanks for your response Manish ! !  will test this shortly and let you know how goes.
AK
Brian Meade Tue, 05/27/2014 - 07:38
  • Silver, 250 points or more
Changing that parameter will definitely work but may cause some problems if users are used to seeing numbers get updated as they are globalized, etc.  Depending on what protocol you are using on the gateway, you can block the connected number from there instead as another option that doesn't change cluster-wide behavior.
Ayaz Khan Tue, 05/27/2014 - 09:59
He Brian,
There is a SIP trunk configured from UCM and GW.  The GW is also registered as H323.  Could I use translation-pattern to change the behavior for just the forwraded calls.
i.e User calls ext 2000 --> 2000 call-forward all to 408-123-1234 --> SIP --> GW tranlate 408-123-1234 to Cell-phone number
wondering if this way would avoid making a global change.
Thanks for you response,
AK
Brian Meade Tue, 05/27/2014 - 10:33
I'm not sure of an easy way to block the connected number with SIP.
For H.323, you can change the "Block Connected Number IE" service parameter to true or configure "no supplementary-service h225-notify cid-update" under voice service voip on the GW.
This is assuming the number isn't changing until the cell phone answers.  If it changes during ringing, Always Display Original Dialed Number is going to be the easiest way.
