Warning message
added resource for video bridge funtionality on be6k
May 26th, 2014
Hello Pros,
I have an issue i hope to get it resolved.
pls have attached a BOM from a client for all to see,
reason are that the clients wants to have a video
bridge functionality as a solution but from their BOM
i did notice that mid density be6k has its limitations
when trying to add more virtual resources like the
vTelepresence server and the conductor to assist
on the bridge functionality.
Now pls advice me what can be done from the attached
document to allow for effective video bridge resources
and probably a codian kind of auto attendant for the client.
i really feel that resource has been exhausted on this vServer.
pls advice.
thanks for your help in advance
eaniefiok
Tommer Catlin Wed, 05/28/2014 - 07:37
  • Green, 3000 points or more
Have you gone through and done a Collaboration Virtual Machine layout?   http://tools.cisco.com/ucs   You can do this manually also with Visio, but the tool makes it very quick to layout the requirements on how it works and should work with the apps.
The BE6K hardware will limit you on the vTS app.  Minimum is 16 cores (8) HD ports.   If you place conductor in front of the vTS, you will get more bang for your buck.
