connect directly to a VTY greater than 0-4
May 26th, 2014
Hi all.
Is there a possibility to connect directly to a specific vty via Telnet or ssh?
The fact is: I have a misconfigured switch with no athentication on line vty 0 4, but with the correct configuration on vty 5-15.
So I would like to know if there is a possibility to specify the linie vty I'll connect.
Thanks for your help.
Best regards
Markus
e.ciollaro Mon, 05/26/2014 - 08:23
  • Silver, 250 points or more
I don't know if it is possible but why don't you try to open 5 telnet so that the firs 4 vty are busy and the fifth will use one of the other ?
Bye,
e
Marvin Rhoads Mon, 05/26/2014 - 09:39
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
I agree with e's approach. I don't believe you can initiate a connection to a specified vty line - IOS will always use the next available open line..
You'll need to launch SIX simultaneous connections. The first five will hit vty 0-4 (five lines) and the sixth should be to vty 5.
You could also use console. :)
