05-26-2014 09:18 AM - edited 02-21-2020 07:39 PM
Hello Everyone,
I know you have seen a number of these types of questions but I have a issue that is rather irritating to me.
OS: Windows 8.1 Pro
32-bit or 64-bit: 64-bit
AnyConnect version: anyconnect-win-3.0.5080-web-deploy-k9
Whenever I install the AnyConnect vpn on a new Windows 8.1 or Windows 8 machine I always seem to have the following issue... Unable to connect to the internet once the VPN is connected. I am able to access the VPN sites without a hitch and anything that requires the VPN works fine. But anything outside the VPN gives me an error such as bad DNS probe or Unable to connect.
I have been able to fix this in the past by using a regsvr32 command but I no longer remember which DLL I needed to re-register. I have found the following errors in my Windows Event viewer after installing and attempting to connect.
Function: FileMoveFiles
File: ..\Common\Utility\NativeSysFileCopy.cpp
Line: 394
Invoked Function: ::FindFirstFile
Return Code: 3 (0x00000003)
Description: The system cannot find the path specified.
Function: wWinMain
File: .\InstallHelper.cpp
Line: 239
Invoked Function: FileMoveFiles
Return Code: -33554423 (0xFE000009)
Description: GLOBAL_ERROR_UNEXPECTED
Line: 394
Function: wWinMain
Line: 239
Line: 394
Function: wWinMain
Line: 239
Function: URL::URL
File: .\Utility\URL.cpp
Line: 46
Invoked Function: URL::setURL
Return Code: -28508150 (0xFE4D000A)
Description: URL_ERROR_BAD_URL
parameter=
Function: CHttpProbeAsync::OnOpenRequestComplete
File: .\IP\HttpProbeAsync.cpp
Line: 254
Invoked Function: CHttpSessionAsync::OnOpenRequestComplete
Return Code: -31522780 (0xFE1F0024)
Description: SOCKETTRANSPORT_ERROR_CONNECT_TIMEOUT
Function: CNetEnvironment::TestAccessToSG
File: .\NetEnvironment.cpp
Line: 1024
Invoked Function: CNetEnvironment::analyzeHttpResponse
Return Code: -28901363 (0xFE47000D)
Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
Function: CThread::invokeRun
File: .\Utility\Thread.cpp
Line: 376
Invoked Function: IRunnable::Run
Return Code: -32047093 (0xFE17000B)
Description: BROWSERPROXY_ERROR_NO_PROXY_FILE
Function: CNetEnvironment::logProbeFailure
Line: 1073
Invoked Function: CHttpProbeAsync::SendProbe
Return Code: -27000818 (0xFE64000E)
Description: HTTP_PROBE_ASYNC_ERROR_CANNOT_CONNECT
HTTP (host: mus.cisco.com)
Troubleshooting steps taken:
Uninstalled VPN completely
Reinstalled as Administrator
Searched far and wide on google for possible fixes
Set AnyConnect adapter to the following settings:
Original settings: http://puu.sh/926tB.png
Modified:
Ensured that ICS was turned off on primary connection.
So, anyone got any ideas on what to do from here? I am officially lost.
05-26-2014 10:09 AM
First off, is the VPN configured to allow split tunneling? It's not always allowed by the ASA policy. You can check if only certain remote networks or all networks (0.0.0.0 0.0.0.0) are to use the VPN via the AnyConnect details (call up AnyConnect while on VPN, click the gear icon and choose VPN, route details on the resultant display).
Second, AnyConnect 3.0.5080 is about 2-1/2 years old and is not officially supported for use with Windows 8 (much less 8.1).
Would it be possible to install a more recent AnyConnect version that supports Windows 8.1?
05-26-2014 10:20 AM
Unfortunately, I am unsure if I am able to get a newer version of the AnyConnect. The version that I listed is the one that is provided from my employer and I don't know if their systems can handle a newer version at all.
05-26-2014 10:25 AM
Re the version, you'd have to take that up with your employer then. Updating the AnyConnect pkg file on an ASA is a simple 5-minute task but they may want to hold off for reasons of their own. Still, if they expect you to connect with a current OS they should be keeping the packages more up to date.
What about the first question I asked?
05-26-2014 11:12 AM
05-26-2014 11:17 AM
I was able to update the version to 3.1.02026 but I still am unable to connect to the internet once connected to it.
05-26-2014 01:14 PM
3.1.02026 supports Windows 8. Were you not able to get a copy of 3.1.04072 (or later 3.1.05060 is current) which is recommended to support Windows 8.1?
Is it just the DNS lookups that fail? i.e. - what happens if you ping 8.8.8.8?
05-26-2014 01:25 PM
Unfortunately no I was not able to get a newer version than 3.1.02026. I am unable to download it from the Cisco website due to my employer having the contract and not myself.
C:\Windows\system32>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=38ms TTL=46
Reply from 8.8.8.8: bytes=32 time=37ms TTL=46
Reply from 8.8.8.8: bytes=32 time=36ms TTL=46
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 36ms, Maximum = 38ms, Average = 37ms
C:\Windows\system32>tracert google.com
Unable to resolve target system name google.com.
05-28-2015 03:25 PM
Hi Kurotsuki,
did you get this to work?, I have the same issue :(
Kind regards
05-29-2015 09:53 AM
Rodrigo,
Are you having the same issue using the latest AnyConnect 3.1.08009?
05-26-2014 04:24 PM
05-26-2014 04:42 PM
As we can see from your successful ping and failed name resolution, it's DNS that's failing. Your logs indicate you are getting two DNS server entries via the VPN but the AnyConnect client isn't working well with Windows 8.1 split DNS
I'm not positive it's fixed in the latest AnyConnect but it's worth a try. Send me a PM for a link to the latest installer.
05-26-2014 06:56 PM
I sent you a message as you had requested.
05-27-2014 05:42 AM
Sorry, but your account isn't allowing PM replies. If you want to PM me your email I can reply to that.
05-27-2014 08:23 AM
I sent you a new message with my email. However I think I found the root cause of my issue...
When looking at my default DNS servers they were listed as IPv6, IPv4, IPv4 in that order. So when the VPN attempted to connect it attempted the IPv6 DNS first but failed as the VPN is set up to not use IPv6. I simply disabled my IPv6 for the time being until I can get a better fix.
