Cisco ASA 5520 - how to download startup-config with putty's pscp
May 28th, 2014
Good day,
I am curious where a startup-config is being stored.I try securely download startup-config to windows C:\Temp file, but FW is disconnecting pscp request.
Our Cisco ASA has single mode context.
When I try to download any file located in disk0:/ I am able to.
C:\Program Files\PuTTY>pscp.exe -scp -v [email protected]:/asa.bin C:\Temp\
But when I try startup-config, or startup.cfg:
C:\Program Files\PuTTY>pscp.exe -scp -v [email protected]:/startup-config C:\Temp\
Using username "admin".
[email protected]'s password:
Sent password
Access granted
Opened channel for session
Started a shell/command
Using SCP1
Connected to XXXXX
Server sent command exit status 0
Disconnected: All channels closed
Lost connection
Please advice how can I download startup-config with pscp.
Thank you
Please contact me on [email protected]
Jozef
James Leinweber Thu, 05/29/2014 - 17:05
  • Silver, 250 points or more
I think the startup config may be in hidden NVRAM.  Try logging into the firewall and doing
   copy startup-config export.txt
first, and then use the Putty pscp.exe client on export.txt.  You'll have to explicitly specify the destination file name, in my experience, e.g.
  pscp.exe -scp -v [email protected]:/export.txt C:\temp\export.txt
-- Jim Leinweber, WI State Lab of Hygiene
Related Content
