Soft phone for MAC OS
noc
Hello All,
Could any one of you guide me if i can use Cisco IP Communicator on MAC OS Machine as well. My CME is using SCCP and i do not want to use SIP, is there any way or any IP Soft Phone Available which work on MAC.
I really Appreciate the Reply..
Best Regards,
Atif
Jaime Valencia
A quick search on CSC would have provided the answer to your question, this has been asked plenty of times before. PLEASE, search CSC for answers before posting a question.
No, IPC is Windows only.
java
if this helps, please rate
Nadeem Ahmed
There is a Cisco softphone that can be installed on Mac OS ie CUPC however it require CUPS(Cisco Unified Presence Server) for its configuration & Integration with Call Manager.
Other than that you can use thrid party SIP client available as open source on google named ("x-lite) for MAC as a SIP endpoint in Call manager or CME.
refer to this thread as well
https://supportforums.cisco.com/discussion/11328756/ip-communicator-apple-mac
Br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
