Warning message
AVC, Netflow and Flexconnect APs
May 29th, 2014
Hi all,
I have few questions - if anybody was solving the same problem.
My situation : few branches with Flexconnect APs (in every of them). APs are set for some SSIDs as locally switched (to save WAN connectivity) and some are centrally switched. WLC code 7.4.
I was very looking forward to implement AVC. AVC works fine but only on centrally switched SSID - this is a big problem.
Is there any chance how to export traffic info for locally switched SSID?
I was wondering if LAP can serve as Netflow source (when I'm unable to see AVC data)?
Any idea?
Thnx
Overall Rating: 4 (1 ratings)
Sandeep Choudhary Thu, 05/29/2014 - 02:17
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
HI,
First: AVC will not work if  you have locally swicthed.
if you checked the local switching under the SSID, then the AP will handle the traffic on its own, without sending the packets to the WLC, hence the WLC does not know what the users are using.
2nd : http://mrncciew.com/2013/02/12/configuring-netflow-on-wlc-7-4/
Reagrds
Pavel Pokorny Thu, 05/29/2014 - 03:30
Thnx for link, know this site.
But, I'm afraid when local switching is in action, then Netflow export from WLC will not show locally switched traffic - for the same reason as AVC. Or am I wrong?
Thnx
Sandeep Choudhary Thu, 05/29/2014 - 03:32
    2017 Wireless
AS per my knowledge: yes you are right. Its not possible.
Dont forget to rate helpful posts
Trending Topics - Security & Network
