Warning message
IronPort c170 SMTP route
May 29th, 2014
Hello.
I've got an email domain, say, example.com and c170 as relay for it.
There is two destination servers, say 10.1.1.1 and 10.2.1.1 in SMTP routes with the same priority.
Is there any way to get an email delivered to both of them,
not on round-robin basis as in goes now.
Robert Sherwin Tue, 06/10/2014 - 19:41
  • Cisco Employee,
Have you tried to use content filter, and select the "Send Copy (Bcc:)" - using the second SMTP as the delivery?
Looking @ detail for the action:
Using either the DNS name, or direct IP address... my example, I have robert.com routing to /dev/null, since I do not have a secondary delivery option...
Tue Jun 10 22:38:42 2014 Info: New SMTP ICID 93 interface Management (172.16.6.165) address 172.16.6.1 reverse dns host unknown verified no
Tue Jun 10 22:38:42 2014 Info: ICID 93 ACCEPT SG UNKNOWNLIST match sbrs[none] SBRS rfc1918
Tue Jun 10 22:38:42 2014 Info: Start MID 56 ICID 93
Tue Jun 10 22:38:42 2014 Info: MID 56 ICID 93 From: <[email protected]>
Tue Jun 10 22:38:42 2014 Info: MID 56 ICID 93 RID 0 To: <[email protected]>
Tue Jun 10 22:38:42 2014 Info: MID 56 Message-ID '<[email protected]>'
Tue Jun 10 22:38:42 2014 Info: MID 56 Subject 'alt_mail test 10:38PM'
Tue Jun 10 22:38:42 2014 Info: MID 56 ready 7748 bytes from <[email protected]>
Tue Jun 10 22:38:42 2014 Info: MID 56 matched all recipients for per-recipient policy mygmail_inbound in the inbound table
Tue Jun 10 22:38:42 2014 Info: Start MID 57 ICID 0
Tue Jun 10 22:38:42 2014 Info: MID 57 was generated based on MID 56 by bcc filter 'alt_mail_delivery'
Tue Jun 10 22:38:42 2014 Info: MID 57 ICID 0 From: <[email protected]>
Tue Jun 10 22:38:42 2014 Info: MID 57 ICID 0 RID 0 To: <[email protected]>
Tue Jun 10 22:38:42 2014 Info: MID 57 DomainKeys: cannot sign - no profile matches [email protected]
Tue Jun 10 22:38:42 2014 Info: MID 57 DKIM: cannot sign - no profile matches [email protected]
Tue Jun 10 22:38:42 2014 Info: MID 57 ready 7750 bytes from <[email protected]>
Tue Jun 10 22:38:42 2014 Info: MID 57 queued for delivery
Tue Jun 10 22:38:42 2014 Info: MID 56 queued for delivery
Tue Jun 10 22:38:42 2014 Info: Delivery start DCID 0 MID 57 to RID [0]
Tue Jun 10 22:38:42 2014 Info: Message done DCID 0 MID 57 to RID [0]
Tue Jun 10 22:38:42 2014 Info: MID 57 RID [0] Response '/dev/null'
Tue Jun 10 22:38:42 2014 Info: Message finished MID 57 done
Tue Jun 10 22:38:42 2014 Info: New SMTP DCID 32 interface 172.16.6.165 address 173.36.13.143 port 25
Tue Jun 10 22:38:42 2014 Info: DCID 32 TLS success protocol TLSv1 cipher RC4-SHA
Tue Jun 10 22:38:42 2014 Info: Delivery start DCID 32 MID 56 to RID [0]
Tue Jun 10 22:38:42 2014 Info: Message done DCID 32 MID 56 to RID [0]
Tue Jun 10 22:38:42 2014 Info: MID 56 RID [0] Response '2.0.0 s5B2cjD5005326 Message accepted for delivery'
Tue Jun 10 22:38:42 2014 Info: Message finished MID 56 done
Tue Jun 10 22:38:47 2014 Info: DCID 32 close
Tue Jun 10 22:39:38 2014 Info: ICID 93 close
I hope this helps!
-Robert
(*If you have received the answer to your original question, and found this helpful/correct - please mark the question as answered, and be sure to leave a rating to reflect!)
