How to use L3 switch and firewall at the edge
May 29th, 2014
Can anyoneplease explain how do we configure our L3 switch and firewall in the following scenario.
1- We want to configure our vlans on L3 switch and and would also want to use firewall to restrict incoming traffic to our network as we have alot of virtual machines
2- Second concern is to not allow any intervlan routing through the l3 switch and if needed i guess we can achieve this using policy based routing?
3- In which mode the firewall will be operating? We dont want to use transparent mode because it doesn't allow IPsec vpn's. Any suggestions?
4- We have our IP range which will be routing from our network provider to one of our internal network device 'which in this case will be either 'L3 Switch or firewall' ? Which one will be better to use in this case? And if we route our IP range to firewall then how the routing will work between the vlans on L3 switch and the firewall?
5- We have 5525 ASA which have 1GB throughput and can handle upto half a million session established, i heard that the throughput won't help if a hacker tries synflood attack to create hundreds of thousands of connections and take the network down. Is this right?
Network Diagram:
Network Provider (ISP)
L2 Switch (Being used for expansion)
Firewall (ASA 5525)
L3 Switch (3750)
Virtual Machines (Hosts)
My apologies in advance if i have asked a stupid question above as i dont have enough experience. :)
Umar Hanif
Jack Leung Thu, 05/29/2014 - 15:32
How many vlans are you going to be hosting on those switches?  If you wish to firewall off intervlan communication, then what you can do is take the 3750 and use it as a layer 2 device and put the gateways onto the ASA firewalls.   You can create sub-interfaces under one physical interface (a sub-interface per vlan) or you can split this over more (I believe the 5525s come with 4x 1GE copper interfaces???).   In this situation the firewall would have to be in routed mode.
The concern is valid.   Since this is public facing, any attacker externally, or a compromised machine internally in your network could generate a large connection attack and eat up the state table of the ASA.   This concern applies for any appliance, or server.
Related Content
