Showing results forĀ
Search instead forĀ
Did you mean:Ā
interface link trap in ios-xr
Sushant Kaliraj
How to enable interface link trap in cisco ASR9010? and how to verify it?
I have enabled it on my ios-xr, i"m getting  all traps except interface link trap.
Thank you.
xthuijs
hi there,
yup possible, you may need to configure
snmp-server traps snmp linkup
snmp-server traps snmp linkdown
and
RP/0/RSP0/CPU0:A9K-BNG(config)#snmp-server trap link ietf
RP/0/RSP0/CPU0:A9K-BNG(config)#commit
Mon Jun  2 14:07:05.833 EDT
RP/0/RSP0/CPU0:Jun  2 14:07:05.908 : config[65901]: %MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user 'root'. Use 'show configuration commit changes 1000000005' to view the changes.
it could be your trap server doesn't like the cisco format of the trap hence that ietf may make that difference.
RP/0/RSP0/CPU0:A9K-BNG(config)#do debug snmp pa
Mon Jun  2 14:07:10.935 EDT
RP/0/RSP0/CPU0:A9K-BNG(config)#int g 0/0/0/0
RP/0/RSP0/CPU0:A9K-BNG(config-if)#shut
RP/0/RSP0/CPU0:A9K-BNG(config-if)#commit
Mon Jun  2 14:07:15.169 EDT
LC/0/0/CPU0:Jun  2 14:07:15.188 : ifmgr[209]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/0, changed state to Administratively Down
RP/0/RSP0/CPU0:Jun  2 14:07:15.192 : snmpd[1125]: t8 snmp_is_dst_address_reachable:Successfully got src address:1.0.0.3 to dest:1.0.0.3 in vrf:Default, vrf_id:1610612736, ifhandle:0x40
RP/0/RSP0/CPU0:Jun  2 14:07:15.193 : snmpd[1125]: t8 Src address updated as :3.0.0.233
RP/0/RSP0/CPU0:Jun  2 14:07:15.193 : snmpd[1125]: t8 snmp_send_pdu_udp_transport: Q-ing TRAP[sp 161, dp 41472]
RP/0/RSP0/CPU0:Jun  2 14:07:15.193 : snmpd[1125]: t8 snmp_is_dst_address_reachable:Successfully got src address:1.0.0.3 to dest:1.0.0.3 in vrf:Default, vrf_id:1610612736, ifhandle:0x40
RP/0/RSP0/CPU0:A9K-BNG(config-if)#RP/0/RSP0/CPU0:Jun  2 14:07:15.193 : snmpd[1125]: t8 Src address updated as :3.0.0.233
xander
xthuijs
hi there,
and
xander
thank you
