Warning message
IMP: Cisco AIR-CAP1602 &1532 not joining 2504 Controller issue
Jun 2nd, 2014
Dear Team, We have Cisco wireless implementation in clients premises. We have 8 indoor AP (AIR-CAP1602E-AK9) and 2 Outdoor AP (AIR-CAP1532I-AK9) . Seven indoor APs are able to join the 2504 controller, but 1 indoor AIR-CAP1602E AP is not joining and signal is RED continuously while as outdoor AP AIR-CAP1532I-AK9 signal goes blinking from green, red to amber continuously and is not downloading LWAPP image from the controller even after hard reset.
The output for both APs shown below-
1) AIR-CAP1602E-A-K9:
C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Compiled Fri 30-Nov-12 15:48 by aselvara
ap: reset
Are you sure you want to reset the system (y/n)?y
System resetting...
Boot from flash
IOS Bootloader - Starting system.
 FLASH CHIP: Spansion S25FL256
Xmodem file system is available.
flashfs[0]: 14 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31936000
flashfs[0]: Bytes used: 418304
flashfs[0]: Bytes available: 31517696
flashfs[0]: flashfs fsck took 9 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 18:e7:28:d1:9b:05
 ************* loopback_mode = 0
The system is unable to boot automatically because there
are no bootable files.
Compiled Fri 30-Nov-12 15:48 by aselvarag
Same event repeating, failed to reset and reboot device
2) AIR_CAP1532I-A-K9 (Outdoor AP):
*Mar  1 00:01:22.211: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:01:22.211: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_47:32:e4'running version 7.5.102.0 is rejected.
*Mar  1 00:01:22.211: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:22.211: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:22.211: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:22.211: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 100.1.1.20
signal goes blinking from Grean, Red to Amber continuously.
Failed to download LWAPP image from the controller even after hard reset.
Default image: 7.6.95.12
Logs and screen shot attached
Please advice.
Aakash
Sandeep Choudhary Mon, 06/02/2014 - 08:58
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
1. 1602 AP should join to WLC. Paste the entire console output from AP after a reboot.
also paste the output from AP: sh version
from WLC: sh sysinfo
2.*Mar  1 00:01:22.211: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_47:32:e4'running version 7.5.102.0 is rejected.
Solution:Right now you have 7.5.102.0 software image on wlc.
You need atleast 7.6.100.0 version to connect this AP to WLC.
Check this matrix: http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compa...
Dont forget to rate helpful posts
aakashojha Tue, 06/03/2014 - 03:12
Hi please note the details below-
AIR-CAP1602E-A-K9:
ap: reset
System resetting...
Boot from flash
is no bootable files.
Can't reboot device!
WLC-SYSLOG
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.5.102.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_47:32:e4
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 100.1.1.20
Last Reset....................................... Power on reset
System Up Time................................... 0 days 2 hrs 18 mins 39 secs
System Timezone Location......................... (GMT -6:00) Central Time (US a        nd Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +32 C
External Temperature............................. +37 C
Fan Status....................................... 4000 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 0
Burned-in MAC Address............................ 24:E9:B3:47:32:E0
Maximum number of APs supported.................. 15
Sandeep Choudhary Tue, 06/03/2014 - 03:49
    2017 Wireless
Hello Ojha ji,
Please paste the output of this from AP: sh version
Also check: Did you hv configured AP policies on ur WLC? What is "show auth-list" output looks like on ur WLC?
If so u need to add AP eth MAC on to this list.
aakashojha Tue, 06/03/2014 - 04:08
We can not access the 1602 Access point. Once we reset the device and it initializes loading but t gets stuck and keeps repeating the same thing. Error: The system is unable to boot automatically because there is no bootable files.
# Show auth-list Output:
AUTH_LIST
(Cisco Controller) >show auth-list
Authorize MIC APs against Auth-list or AAA ...... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
  AP with Manufacturing Installed Certificate.... yes
  AP with Self-Signed Certificate................ no
  AP with Locally Significant Certificate........ no
Mac Addr                  Cert Type    Key Hash
78:da:6e:59:d4:0c         MIC
Sandeep Choudhary Tue, 06/03/2014 - 04:29
    2017 Wireless
auth-list is ok.
something is fish, you must provide the log from AP console.
This means that image is corrupt.
You must relaod this AP or upgarde it.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/conversion/lw...
Download the new image from Cisco.com or load the image on to the AP using archive download-sw command using the tftp, the issue will get resolved!!
aakashojha Tue, 06/03/2014 - 09:17
i tried uploading the image to the Air-Cap1602 LWAP but failed to have it installed, i have both recovery and base image-
Loading image from the TFTP server:
button is pressed, wait for button to be released...
button pressed for 58 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap1g2-k9w7
examining image...
%Error opening tftp://255.255.255.255/ap1g2-k9w7-tar.default (connection timed out
Please advice--
I also have the IOS  upgrade for WLC2504 to 7.6.200.0 from Cisco, as per the support matrix this should support 1532i outdoor Aps. Wanted to know  if  there will be any issue for the Licensing part if i upgrade the image in the controller? My Controller has 15 license by default,and do not have license file or paper PAK since it was loaded in the device itself.
Please advice---
Sandeep Choudhary Tue, 06/03/2014 - 09:23
    2017 Wireless
You have to reset AP by mode button.
paste teh complete info of this command from AP: sh version
yes 1532i outdoor AP will support WLC with 7.6.200.0 version. If you have enough AP license(you can not add more then 15 AP) then it will not create problem.
You can add 15 AP on this WLC without any additional license.
aakashojha Tue, 06/03/2014 - 10:04
1)  i cant get into AIR-CAP1602 unless i have the image installed.
2) i am upgrading Controller image with 7.6.200.0 in the 2504 ctr. Should i do anything for the licensing (15 Ap License) part while upgrading the IOS in the controller?  or will it work after upgrading the IOS as the license are coded in the box itself?
3) will i be able to upgrade from 7.5.102.0 to 7.6.120.0 ? or do i need to upgrade first to 7.6.100.0 and then to 7.6.120.0 ?
~~quite lame :D
Please advice :)
Sandeep Choudhary Tue, 06/03/2014 - 10:07
    2017 Wireless
1. Yes you must reset AP or insatll the image via TFTP.
2. NO need. It will work as usual after software upgrade.
3. You can upgrade directly to 7.6.120.0.
aakashojha Tue, 06/03/2014 - 22:17
i cant install the Image in the Air-CAP1602..
examining image...
Please advice--
Sandeep Choudhary Tue, 06/03/2014 - 23:04
    2017 Wireless
I think 1602 AP has and Autonomous Image(k9w7).
You must download a k9w8 image from cisco and upload to AP.
1. Connect AP with your laptop, the laptop IP must be 10.0.0.2.(AP and laptop must be in same subnet).
2. Open TFTP on your laptop and put the Lightweight image on tftp root directory.
3. Download the LWAPP image(W8) from the Cisco website and get the console access the AP and just issue the command..
archive download-sw/overwrite/force-reload tftp://<IP address of the  TFTP server>//<image>
Check this post:
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-a...
aakashojha Wed, 06/04/2014 - 21:53
Getting the same error--
downloaded WIRELESS LAN LWAPP Image:  ap1g2-k9w8-tar.152-4.JB5.tar  and tried installing in the AIR-CAP1602e-a-k9 , ends up with connection time out
BS_AP_03 uptime is 6 minutes
System image file is "flash:/ap1g2-k9w8-mx.152-4.JA1/ap1g2-k9w8-mx.152-4.JA1"
Last reload reason:
__________
examining image...
%Error opening tftp://255.255.255.255/ap1g2-k9w8-tar.default (connection timed out
Please advice--
