Prime Infrastructure - LMS License Kit
Answered Question
Jun 3rd, 2014
We recently bought a LMS to Cisco Prime Infrastructure 2.x Upgrade because we had plans to migrate LMS 4.1 to Prime Infrastructure 2.0
In fact, we did not do the upgrade, but we installed Prime Infrastructure 2.0 on a new, separate server. We purchased a 100-device license for this Prime Infrastructure.
Now I have this LMS License Kit (L-PILMS42-KIT) for LMS 4.2 on my hands, and I would like to install LMS 4.2 on another server, and get rid of my LMS 4.1.
My question is : can I use the same 100-device license for LMS 4.2 also ? Do i need to purchase another license separately for LMS 4.2 ? Or can I maybe "split" my device count between Prime Infra 2.0 ans LMS 4.2 ?
Thank you
Correct Answer by AFROJ AHMAD about 3 years 2 months ago
Hi ,
you should be able to use the same license of LMS 4.1 on LMS 4.2 .
As you are installing the new server which might have a new HOSTNAME then you need to contact the new license for you with the new host name of the server.
device count split between PI 2.0 and LMS 4.2 would be possible AFASIk.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Overall Rating: 5 (2 ratings)
Correct Answer
AFROJ AHMAD Tue, 06/03/2014 - 02:11
  • Cisco Employee,
Hi ,
Thanks-
Afroz
jeremygoutal Tue, 06/03/2014 - 02:36
Thank you Afroz.
Would this mean that my LMS 4.2 License Kit is useless because I already have a LMS 4.1 installed ?
Also, how do you do device splitting between PI and LMS ?
AFROJ AHMAD Tue, 06/03/2014 - 02:40
  • Cisco Employee,
As you already have license for 4.1 which work fine on LMS 4.2 , you can say that..
or you can use this LMS 4.2 kit as well. I mean both will serve the same purpose.
Thanks-
Afroz
Marvin Rhoads Tue, 06/03/2014 - 07:38
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
You can just upgrade your LMS to the current release in place and don't need to add the new license file. The format did not change from LMS 4.1 to LMS 4.2.
By the way, the PI -LMS "license splitting" is strictly honor system. There's no software enforcement of which ones are in use on which platform - your license only enforces the top level of your overall license on a given platform.
AFROJ AHMAD Tue, 06/03/2014 - 07:58
  • Cisco Employee,
Hi ,
In case you don't want to installed LMS 4.2 on new server ,it is absolutely fine what Marvin suggested.
Thanks-
Afroz
Related Content
