Cisco Secure ACS v 4.2
Jun 3rd, 2014
Hi There
We have Cisco Secure Acs v 4.2 and we are running it in parallel with Active Directory to Authenticate users to access Juniper/Cisco devices. For all users except "root and admin"
Since "admin" user is only defined on Juniper devices and ACS so we have to change admin password on both ends. I have changed admin password on Juniper devices and now need to change the same on ACS.
All I need to confirm that I am changing the password from exact location.
ACS Admin -----> usres list -----> choose "admin" user ---> from user setup section ------> choose password authetication methos as "ACS internal database" ----> change the password from the option.
Please let me know if you require any additional information.
edwardcollins7 Wed, 06/04/2014 - 02:20
  • Bronze, 100 points or more
Yes, this is right procedure.
Rate if Useful :)
Sharing knowledge makes you Immortal.
Ed
hadiyah07 Wed, 06/04/2014 - 04:33
Hi There
Thanks for reply.
There are couple of other password options which I want to understand where exactly these are applied. I have attached some print screen to better clarify my concern.
1 - All users authetication - We are using windows datadase (AD) in this case to be used for password authentication.
2 - Admin user authentication - we are using ACS internal databse in this case for password authentication.
3 - Other password options - There are 2 sections and I am not able to calrify their exact implementation.
i- TACACS+ enable password - we are not using this option. Then second option, it says, "use separate password" ---->> what exactly is the purpose of these ?
ii - TACACS+ Outbound Password
(Used for SendPass and SendAuth clients such as routers) -----> where exactly this optin is used and in which scenario.
Thanks in advance !!
hadiyah07 Mon, 07/07/2014 - 03:44
Hi Guys
Any help will be highly appreciated
I am using above mentioned steps but the change is not happening. where exactly I am making mistake ? is it required to make change only with Admin account ?
