Warning message
ACS upgrade from 5.2 to 5.4 on VM - urgently need your valuable advises
Jun 3rd, 2014
Hello all,
I need to upgrade ACS 5.2 to 5.4  patch 3. I got one ACS appliance and other one is on VM.  I'm concerning about the VM version when I upgrade the ACS from 5.2 to 5.4.  Will ACS work after I done the upgrade on the same VM ? What are the things that I should prepare before the upgrade?  What are the files that I have to download from smartnet?
Also please post a document of Matrix for supported VMs and ACS versions.
in the mean time I found two articles which are describing the system requirements.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_contro...
For the upgrade also do we need to have these specs on the VM server?  if yes I have to do is reimaging upgrade right?
Thank you for your valuable time and consideration
Kind regards
Chamara
Related Content
Trending Topics - Security & Network
