Warning message
Cisco 819G 3G Problem
Jun 4th, 2014
We have a Problem with a 819G Router 4G (LTE) connection is working but if it fails 3G connection cannot be established.
here is my configuration:
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = internet.t-d1.de
Authentication = PAP
Username: t-mobile
Password: tm
chat-script GSM "" "AT!CALL1" TIMEOUT 20
interface Cellular0
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer idle-timeout 4800
 dialer string GSM
 dialer-group 1
 no peer default ip address
 async mode interactive
ip nat inside source list NAT interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
line 3
 script dialer GSM
 modem InOut
 no exec
 transport input all
 transport output all
a short log
*Jun  3 12:49:21.707: Ce0 DDR: place call
*Jun  3 12:49:21.707: Ce0 DDR: Dialing cause ip (s=192.168.10.101, d=8.8.8.8)
*Jun  3 12:49:21.707: Ce0 DDR: Attempting to dial GSM
*Jun  3 12:49:21.707: CHAT3: Attempting async line dialer script
*Jun  3 12:49:21.707: CHAT3: Dialing using Modem script: GSM & System script: none
*Jun  3 12:49:21.707: CHAT3: process started
*Jun  3 12:49:21.707: CHAT3: Asserting DTR
*Jun  3 12:49:21.707: CHAT3: Chat script GSM started
*Jun  3 12:49:21.707: CHAT3: Chat script GSM finished, status = Success
*Jun  3 12:49:23.487: Ce0 DDR: disconnecting call
*Jun  3 12:49:38.487: Ce0 DDR: re-enable timeout
A strange behaviour is no response on the chat script, so when i configure an expected string t runs ito a timeout
Volker
v.duee Mon, 09/01/2014 - 03:04
Hello, if someone is interested
the modem hardware has changed and supports not longer PPP enc, so Chat script has to be changed
chat-script gsm "" "AT!SCACT=1" TIMEOUT 60 "OK" (for two SIM cards)
