Warning message
Upgrades using PCD on same hardware
Jun 4th, 2014
I am hoping someone can answer the following for me.
In reading the PCD release notes, I see the following under Upgrade Tasks:
Upgrade Task - (Upgrade Application Server or Install COP Files)
  • Unified CM Releases Supported: 8.6(1-2), 9.0.(1), 9.1(1), 9.1(2), 10.x
  • Cisco Unified Presence (CUP) Releases Supported: 8.6(3), 8.6(4), 8.6(5)
  • Cisco Unified CM - IM and Presence Releases Supported: 9.0(1), 9.1(1), 10.x
  • Cisco Unified Contact Center Express Releases Supported: 9.0(2), 10.x
  • Cisco Unity Connection Releases Supported:
    • From 8.6(x) to 8.6(x)
    • From 8.6(x) to 9.x
    • From 9.x to 9.x
    • From 10.0(1) to 10.x
      Based on the above, I have the following questions:
  • PCD supports upgrading directly from 8.6(1-2) to 10.x for CUCM.
  • Does it supports upgrading CUP from 8.6.5 to 10.x.
  • It does not support upgrading Unity Connection from 8.6 to 10.x.
  • PCD requires the ISOs, but all I got are the upgrade DVDs. Can I convert the DVD to an ISO or how do I get the ISOs? The download page references it is for upgrading from 10.0.1 to 10.5
It took me a while to find all of this, because most of the stuff I have seen, PCD is being using primarily to do migrations from one platform to another.
Thanks in advance,
Doug
Jaime Valencia Wed, 06/04/2014 - 06:46
  • Cisco Employee,
  • Hall of Fame,
    2011
 PCD supports upgrading directly from 8.6(1-2) to 10.x for CUCM. YES
  • Does it supports upgrading CUP from 8.6.5 to 10.x.YES
  • Unity Connection Releases Supported: 8.6(1-2), 9.x, 10.x
    http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/ucmap/10_0_1/CUC...
Google how to create ISO, or use PUT and ask for download links
You can upgrade to any release you want, only migration is forceful to 10.X
