Warning message
Anyconnect error
Jun 4th, 2014
Hi I have the next error when use the AnyConnect.
The cryptographic algorithms required by the secure gateway do not match those supported by AnyConnect.
this is when I use ipsec with the name, but if I use the ip address it works fine but use de ssl.
Marvin Rhoads Wed, 06/04/2014 - 10:11
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
What version of AnyConnect client are you using?
It sounds like there might be an IPsec (IKEv2) VPN setup on the ASA in addition to the SSL one (or an IPsec IKEv1 VPN for the legacy Cisco VPN client). Older AnyConnect versions (prior to 3.0.0629) do not support IPsec (IKEv2) remote access VPNs (and AnyConnect does not support IPsec (IKEv1) at all).
Marvin Rhoads Wed, 06/04/2014 - 10:13
  • Hall of Fame,
OK, so it's probably an older IPsec VPN that's also setup on the ASA. For some reason when you use the FQDN your client hits that and is unable to negotiate an IPsec VPN (as one would expect).
It's hard to say exactly why without seeing the ASA configuration.
Marvin Rhoads Wed, 06/04/2014 - 10:36
  • Hall of Fame,
That should do it. The configured setup for remote access VPNs should be adequately discernible from the output of:
show run group-policy
show run tunnel-group
Azariel Rodrigu... Wed, 06/04/2014 - 11:18
This is the configuration
group-policy GroupPolicy_VPN_TEST_ANY internal
group-policy GroupPolicy_VPN_TEST_ANY attributes
 wins-server value 192.168.162.2
 dns-server value 192.168.162.2
 vpn-tunnel-protocol ikev1 ikev2 l2tp-ipsec ssl-client
 group-lock value VPN_TEST_ANY
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value aumx-commuter-vpn_splitTunnelAcl
 default-domain none
 webvpn
  anyconnect profiles value VPN_TEST_ANY_client_profile type user
tunnel-group VPN_TEST_ANY type remote-access
tunnel-group VPN_TEST_ANY general-attributes
 address-pool vpnpool
 default-group-policy GroupPolicy_VPN_TEST_ANY
tunnel-group VPN_TEST_ANY webvpn-attributes
 group-alias VPN_TEST_ANY enable
tunnel-group VPN_TEST_ANY ipsec-attributes
 ikev1 trust-point ASDM_TrustPoint1
Marvin Rhoads Wed, 06/04/2014 - 13:27
  • Hall of Fame,
You have all possible protocols enabled in your group-policy:
But you only need ssl-client if your intention is to use the AnyConnect client for an SSL VPN. So there you need to remove the unnecessary ones.
You also have:
...which is not necessary for SSL VPN and should be removed (*unless you have a site-site VPN using certificates)
Azariel Rodrigu... Wed, 06/04/2014 - 13:59
But I want to use ipsec this is the reason I have all the protocols.
The Anyconnect only works if I use the ip address.
Marvin Rhoads Wed, 06/04/2014 - 14:17
  • Hall of Fame,
Hmm.
Does the FQDN you fail to connect with resolve to the IP address? I'm going back to the initial coment you made about "when I use ipsec with the name"
